Milchbilch Posted August 21, 2008 Report Posted August 21, 2008 Hi all! I succesfully could build system services out of LV Applications using srvany and instsrv in the past. Now I get problems when I use classes with overwrite VIs: They do have the same name so the name conflict is solved by the AppBuilder by copying the VIs with the same names to different subfolders. I can start the exe that is built this way. But I cannot start the service I created! I always get "Error 1053: The service did not respond to the start or control request in a timely fashion" I guess this is due to not beeing able to load the VIs from the subfolders. But I am not sure. I made a very easy VI to test it: Containig only 2 VIs with the same name, building the exe, (subfolders are created), exe can be started, created service succesfully, ERROR 1053 when starting the service! I do not know how to solve this. I mean I really do need overwrite VIs and i do need the App to run as a service! Any help is really appreciated. Best regards, Stefan Quote
Aristos Queue Posted August 21, 2008 Report Posted August 21, 2008 Can you please repost this topic over on ni.com here so that AEs can investigate it? If there is a bug that needs to be addressed, that's the best way to get it started. Quote
LAVA 1.0 Content Posted August 21, 2008 Report Posted August 21, 2008 I currently have an application running as a service using srvany and overrided VIs. So it's possible. The only difference with your problem description is the way I manage the overrided VIs. For this application I manually configure the application builder to save classes as a different .llb file instead of letting it copy the file in different directories. This application is build with LV8.5 but if my memory serves, I did the same thing with LV8.2. Quote
Milchbilch Posted August 21, 2008 Author Report Posted August 21, 2008 Thank You fro replying that fast! QUOTE (pdc @ Aug 20 2008, 06:48 PM) I currently have an application running as a service using srvany and overrided VIs. So it's possible. Hmmm... Knowing that - i retried to do the whole thing and guess what - Now it works! I do not know what I did wrong this afternoon. I tried to create this service about 20 times, always successful but it could not be started. So I created another easy Test service without overwriting VIs. It worked so I thought I'd found the problem. However. QUOTE (pdc @ Aug 20 2008, 06:48 PM) For this application I manually configure the application builder to save classes as a different .llb file instead of letting it copy the file in different directories. That is generally a good idea I guess. I will do that in the future. Though I do not know how to, yet. I guess it's an option in the build specifications, right? Time to go home now. Thanks again! Stefan Quote
LAVA 1.0 Content Posted August 21, 2008 Report Posted August 21, 2008 QUOTE (Milchbilch @ Aug 20 2008, 01:19 PM) That is generally a good idea I guess. I will do that in the future. Though I do not know how to, yet. I guess it's an option in the build specifications, right? I would like to say it's just a checkbox, but it's not. In the application builder you have to create multiple Destination with the destination type = LLB. Than, in the source file settings, you can associate VIs, libraries, classes or directories to a custom destination by clicking "Set destination for all contained items". It's not so hard if the project is well organized. Quote
