tmunsell Posted August 22, 2008 Report Posted August 22, 2008 I have been trying to create an installer for my app, but even though I have all the drivers loaded on my laptop, the builder keeps asking for the DVDs. I don't want to have to carry them around with me all the time (I do a lot of my programming while at home). Is there a way to create an installer without needing the DVDs? Will I have to copy each DVD to a folder on my laptop (wasting a lot of disk space)? Thanks! Todd Munsell WGP&W Industrial Turbine Services Quote
Neville D Posted August 22, 2008 Report Posted August 22, 2008 I'm not sure. But you can just build the executable without needing to build the installer every time. Once the code is installed, all you need to do is replace the executable. If building just the exe it won't keep bugging you about the DVD's. Neville. Quote
tmunsell Posted August 22, 2008 Author Report Posted August 22, 2008 I'm sorry, maybe I wasn't explaining the problem clearly. This is a first time installation of the app for the target PC. I want to build the app so it will run with just the run-time engine installed on the target PC, without having to install the entire LV program. But, for the build to work, it needs certain programs such as MAX and the NI-Serial drivers. It's when I select these to be added to the installer that it keeps asking for the DVDs. I'm out of town now, so I don't have access to the DVDs. I want to create the installer and email it to my workplace. Thanks. Todd Quote
Neville D Posted August 22, 2008 Report Posted August 22, 2008 QUOTE (tmunsell @ Aug 21 2008, 02:24 PM) Quote I'm sorry, maybe I wasn't explaining the problem clearly. This is a first time installation of the app for the target PC.I want to build the app so it will run with just the run-time engine installed on the target PC, without having to install the entire LV program. But, for the build to work, it needs certain programs such as MAX and the NI-Serial drivers. It's when I select these to be added to the installer that it keeps asking for the DVDs. I'm out of town now, so I don't have access to the DVDs. I want to create the installer and email it to my workplace. Thanks. Todd Maybe you can download what you need from ni.com? Or get others to download & install required components separately from ni.com, while you send them a simpler build without the addtional components. Or get a local NI rep to drive you the CD's you need. I know, its a pain, whenever I visit a customer-site, I carry along all 15-20 CD's and DVD's of the last two versions of LV + toolkits, just in case. Neville. Quote
tmunsell Posted August 22, 2008 Author Report Posted August 22, 2008 Thanks. I'll see if they can download the files needed. The nearest rep is about 200 miles away from the test cell. I'll also be making backup copies of the DVDs that I can keep in the laptop case when I travel, just in case I need them. Thanks again. Todd Quote
Dan DeFriese Posted August 23, 2008 Report Posted August 23, 2008 Hello Todd, I've never used this feature, but with LV 8.2 and greater you should be able to cache the device drivers and components you need the first time you create an install. From LV 8.2 Help: "... Caching installer components—If you build an installer more than once and the installer contains additional installers or components, caching eliminates the need to specify a location for the additional components each time you build the installer. The first time you build the installer, the Locate Distribution dialog box prompts you to locate the distribution that contains the additional components. Place a checkmark in the Cache component from this distribution checkbox to copy files from the distribution into a permanent location on the local system. The next time you build an installer that includes these components, the Application Builder automatically copies the components from the local system instead of prompting you for a distribution CD. " Hope this helps, Dan DeFriese Quote
ygauthier Posted August 23, 2008 Report Posted August 23, 2008 QUOTE (Dan DeFriese @ Aug 22 2008, 12:29 PM) Quote Hello Todd,I've never used this feature, but with LV 8.2 and greater you should be able to cache the device drivers and components you need the first time you create an install. From LV 8.2 Help: "... Caching installer components—If you build an installer more than once and the installer contains additional installers or components, caching eliminates the need to specify a location for the additional components each time you build the installer. The first time you build the installer, the Locate Distribution dialog box prompts you to locate the distribution that contains the additional components. Place a checkmark in the Cache component from this distribution checkbox to copy files from the distribution into a permanent location on the local system. The next time you build an installer that includes these components, the Application Builder automatically copies the components from the local system instead of prompting you for a distribution CD. " Hope this helps, Dan DeFriese This is a very useful feature indeed. Don't need those DVDs anymore because of this feature! Just a small disclaimer though. This feature will simply copy the DVD's installation files to your harddrive. Basically, building your exe will be easier but you will have to have enough disk space to store the driver installation files to your hard drive. Yvan Quote
george seifert Posted August 26, 2008 Report Posted August 26, 2008 QUOTE (Dan DeFriese @ Aug 22 2008, 11:29 AM) Quote Hello Todd,I've never used this feature, but with LV 8.2 and greater you should be able to cache the device drivers and components you need the first time you create an install. From LV 8.2 Help: "... Caching installer components—If you build an installer more than once and the installer contains additional installers or components, caching eliminates the need to specify a location for the additional components each time you build the installer. The first time you build the installer, the Locate Distribution dialog box prompts you to locate the distribution that contains the additional components. Place a checkmark in the Cache component from this distribution checkbox to copy files from the distribution into a permanent location on the local system. The next time you build an installer that includes these components, the Application Builder automatically copies the components from the local system instead of prompting you for a distribution CD. " Hope this helps, Dan DeFriese That used to work great up to LV 8.5, but I don't think it's available in 8.6. At least I haven't found how to make it cache the components yet. I'd really like to know how to get that feature back. George Quote
george seifert Posted August 27, 2008 Report Posted August 27, 2008 QUOTE (tmunsell @ Aug 21 2008, 12:14 PM) Quote I have been trying to create an installer for my app, but even though I have all the drivers loaded on my laptop, the builder keeps asking for the DVDs. I don't want to have to carry them around with me all the time (I do a lot of my programming while at home). Is there a way to create an installer without needing the DVDs? Will I have to copy each DVD to a folder on my laptop (wasting a lot of disk space)? I finally got LV 8.6 to cache the distributions. NI gave this advice and it worked. In order to get the Locate Distribution dialog box to appear that has the Cache component from this distribution checkbox, you must attempt a build where LabVIEW cannot find the source files needed for the distribution. To do this do not insert the DVD that has the files needed or point to a location that you know does not have the needed distribution files. Then this dialog box will appear asking you to redirect the computer to the correct location of these files. When this Locate Distribution dialog box appears it will include the needed checkbox. George Quote
