Rounding
Hello,
i have found unexpexted rounding effects with the function "Round to nearest integer"
Input 0.5
output 0
Input 1.5
output 2
Input 2.5
Output 2
Input 3.5
Output 3
Labview is alwas rounding to a even integer.... but why?
What is the sense of these implementation of auf Rounding alghorithm?
Thanx
Claude
QUOTE (Cloedu @ Aug 25 2008, 12:00 PM)
as far as I remember this had to do with statistics,
assume you have a big pile of points and they all get rounded up when ending on .5,
you end up with a higher average,
with this statistical rounding, the average would not change that much.
I hope this helps a bit
edit: Ton was a bit quicker in typing as me...
QUOTE (Cloedu @ Aug 25 2008, 06:00 AM)
Hello,
Thanx
Claude
LabVIEW follows IEEE standard
round up the odd whole numbers ending with .5,
round down even numbers ending with .5.
From message by
Lew Drake
Process Automation Corporation, and the info LabVIEW mailing list, 4/12/07.
This method accumulates less error over time, it is statistically defensible. If you look around on line you will find detailed explanations, no problem.
