GaryTan Posted August 27, 2008 Report Share Posted August 27, 2008 Hi everyone, I'm back again with question Anyone know how to use the IMAQ WindZoom Fucntion? Can explain it? As I need to use the zoom in and out function to analysis an image. The built-in function which appears on the display panel can only zoom in and no zoom out. Thx Quote Link to comment
Antoine Chalons Posted August 27, 2008 Report Share Posted August 27, 2008 QUOTE (GaryTan @ Aug 26 2008, 06:24 AM) Hi everyone, I'm back again with question Anyone know how to use the IMAQ WindZoom Fucntion? Can explain it? As I need to use the zoom in and out function to analysis an image. The built-in function which appears on the display panel can only zoom in and no zoom out. Thx Hello, To zoom out, select the zoom tool, hold the shit key and clic on the image display. The major drawback of this is that you cannot control the zoom factor accurately. To be more accurate you have to do it with a property node on the image display and use the SGL zoom factor (you can even use different factors on X and Y). Hope this helps Quote Link to comment
GaryTan Posted August 27, 2008 Author Report Share Posted August 27, 2008 QUOTE (Antoine Châlons @ Aug 26 2008, 02:23 PM) Hello,To zoom out, select the zoom tool, hold the shit key and clic on the image display. The major drawback of this is that you cannot control the zoom factor accurately. To be more accurate you have to do it with a property node on the image display and use the SGL zoom factor (you can even use different factors on X and Y). Hope this helps Ok...Thx for the hints. I will try work on it. :laugh: Quote Link to comment
Neville D Posted August 27, 2008 Report Share Posted August 27, 2008 If you have Vision 8.6, there is a new "zoom-to-fit" option for displaying images. I haven't tried it on a Window yet, but it works great on the IMAQ Image Display. Note there is already an update Vision 8.6.1 N. Quote Link to comment
