LAVA 1.0 Content Posted September 10, 2008 Report Posted September 10, 2008 I was using a muticolumn listbox with 5 columns.In third column,i want to generate a ring control,generate in the sense,whenever user clicks on any cell of third column of multicolumn listbox,the ring control should pop up.The thing is that i need to use only one ring control and whenever user clicks on any cell of a third column,this ring control should pop up.How can i achieve this,anyone please help me, Regards, Naresh.N Quote
Francois Normandin Posted September 10, 2008 Report Posted September 10, 2008 Have a look at this piece of coding. Type Sensitive Popup Quote
Mellroth Posted September 10, 2008 Report Posted September 10, 2008 QUOTE (NareshN@Capsys @ Sep 9 2008, 01:37 PM) In third column,i want to generate a ring control,generate in the sense,whenever user clicks on any cell of third column of multicolumn listbox,the ring control should pop up. QUOTE (normandinf @ Sep 9 2008, 02:50 PM) Have a look at this piece of coding. Type Sensitive Popup Or just use the Contextual menu directly, depends on your needs. /J Download File:post-5958-1220965113.vi Quote
jhoskins Posted September 10, 2008 Report Posted September 10, 2008 QUOTE (JFM @ Sep 9 2008, 08:59 AM) Or just use the Contextual menu directly, depends on your needs./J http://lavag.org/old_files/post-5958-1220965113.vi'>Download File:post-5958-1220965113.vi Or try this. Quote
