Making windows return to the right frame by default
HChandler
Here's what I'm talking about. I design a front panel. I set the properties so that when it pops up it has no scroll bars, like a dialog. There may be some controls or indicators someplace on the panel, some are outside of the frame and are meant to be there. Others are carefully placed within the frame to make a nice display. Then, I get some kind of error. I choose the useful option to go to the error. It pans the panel to show the messed up indicator. I fix the problem. Then, I forget to re-frame the panel to hide the bits and pieces. When the program pops up the sub-panel exposes stuff that's supposed to be out of view, indicators or controls are exposed, and even worse, some important control/indicator gets shoved out of the picture.
Is there any way to lock the frame, or set a default view that always snaps back at run time to what I want it to be in spite of what happens while the program is not running.
Thanks,
Howard
QUOTE (HChandler @ Sep 25 2008, 05:51 PM)
Howard,
Open G has many available toolkits, but there is one with many useful functions dedicated to application control - oglib_appcontrol - it can be found using VIPM offered by JKI. There is a function in the tool kit which will fit your application to the largest decoration - therefore you can surround the part of your application with a decoration that you want to always show when executed and it will ensure you see what you want to.
Hope that helps.
Jon
I developed my interface VIs with the FP origin set at zero. Then, during execution, before you open/display the front panel, use a property node to set the origin to 0 again.
QUOTE (JonMA @ Sep 25 2008, 06:54 PM)
Open G... There is a function in the tool kit which will fit your application to the largest decoration - therefore you can surround the part of your application with a decoration that you want to always show when executed and it will ensure you see what you want to.
:thumbup: Good one Jon - this is one of the OpenG reuse VIs that I use the most: it's in almost every VI that I write that shows it's front panel. I also use the VI that sizes to all objects (with a border of 20 or so pixels) at the end of the VI to show everything again (particularily useful when in development mode).
Trick: you can set the border in the size-to-largest-decoration to a negative number (like -1 or -2) as to not see the border of the decoration.
QUOTE (crelf @ Sep 26 2008, 06:51 AM)
That's good to know. It would make a good addition to the VI Description :thumbup:
QUOTE (mballa @ Sep 26 2008, 10:41 AM)
That would make a good addition to that OpenG palette...
QUOTE (TobyD @ Sep 26 2008, 11:04 AM)
It's open source, so get on over to OpenG.org and make it happen! :)
