Question about 3D Surface / 3D Plane
maybe
Hello,
I have a problem about the CWgraph3D Control, wondering if anyone has idea how to solve my problem.
So I have 3 points in space, and I am using the CWPlot3D->Plot3DMesh and give the x, y and z vector to have my surface /plane plotted. I am using a XY-Projection. and my 3 points are:
P1 : 0 0 1
P2 : 0 1 0
P3 : 0 0 0
And thus my x vector is <0 0 0>, y vector is < 0 1 0 >, z vector is <1 0 0>
And for the XY-Projection, I wil have three points which are:
P1' : 0 0
P2' : 0 1
P3' : 0 0
As you see, two points apperas to be overlaped each other, and I suppose to see a "line" (if the thickness of the plane is not 0) in the XY projection. Instead, in my plot I see nothing there. I tried to chanage the plot style to surface and line and nothing is shown. I assume it is because the plane is defined as 0 thickness. But I really want to show it as a line (so I want to increase the thickness), what can I do?
Thanks.
QUOTE (maybe @ Oct 10 2008, 04:01 PM)
  Quote
Hello,
P1 : 0 0 1
P2 : 0 1 0
P3 : 0 0 0
P1' : 0 0
P2' : 0 1
P3' : 0 0
Thanks.
Sorry but you lost me if it is not a simple as setting the line width for your plot.
Please post an example VI with the data saved as a default so someone can help out without having to code from step one.
Ben
QUOTE (neB @ Oct 10 2008, 09:09 PM)
  Quote
Ben
Hello,
I tried to set line width, and it does nothing to it. Attached are the example and a function which converts color. Thanks.
QUOTE (maybe @ Oct 10 2008, 04:42 PM)
  Quote
Hello,
Try using the method "Plot3DCurve". It gave me the lines I think you are after.
Ben
