Call Parent Method Node
Hi guys,
I'd like to call the parent method inside the child method and would like to restore the "Call Parent Method Node" I erased without having to delete the child and creating it again with the "New>> VI for override..." menu. Certainly it can be done, right?
post-10515-1224081762.png?width=400
The Programming > Cluster, Class & Variant palette has the function you're looking for. It's small, and I've overlooked it myself before.
post-11742-1224083525.png?width=400
QUOTE (MJE @ Oct 15 2008, 11:13 AM)
  Quote
As easy as it gets... I didn't imagine it would change itself with the actual parent icon in the background.
thanks
  • 2 months later...
QUOTE (normandinf @ Oct 15 2008, 09:23 AM)
  Quote
thanks
And it will stay up-to-date conpane wise if you edit your VI or do "save as: rename" to change the VI file name, or if you move the nearest implementation from the immediate parent to some older ancestor or vice versa.
