george seifert Posted October 17, 2008 Report Share Posted October 17, 2008 Is there a way to get an express VI such as Time Delay to show up as an icon when first dropped on the BD? I hate having to go to the menu to switch it over all the time. George Quote Link to comment
Aristos Queue Posted October 17, 2008 Report Share Posted October 17, 2008 There's a tools>>options setting that will change it for all Express VIs. I believe your VI will be broken until you visit the node and configure it. Quote Link to comment
george seifert Posted October 17, 2008 Author Report Share Posted October 17, 2008 QUOTE (Aristos Queue @ Oct 16 2008, 01:31 PM) There's a tools>>options setting that will change it for all Express VIs. I believe your VI will be broken until you visit the node and configure it. I've looked through all the settings and I must be missing it. There's one that says "Configure Express VIs immediately", but that doesn't do what I want. There's another one that says "Place subVIs as expandable", but that also doesn't work. The help for Express VIs doesn't help me either. George Quote Link to comment
Aristos Queue Posted October 17, 2008 Report Share Posted October 17, 2008 Oh. By "drop as icon immediately" I thought you meant "don't bring up dialog." No, there is no token that will cause an Express Vi to immediately convert to a subVI on drop. Quote Link to comment
george seifert Posted October 18, 2008 Author Report Share Posted October 18, 2008 QUOTE (Aristos Queue @ Oct 16 2008, 03:50 PM) No, there is no token that will cause an Express Vi to immediately convert to a subVI on drop. Bummer. There should be. Quote Link to comment
Yair Posted October 19, 2008 Report Share Posted October 19, 2008 Other than the normal advice you would get from some vocal members of not using express VIs, here are two things you can try - Call the subVI called by the express VI directly. You won't get the config dialog and you will have to set up an easy way to do this, as the VI will not be in the palettes by default. Create a blank VI and place the express VI in it. Then change the display and add the calling VI to your palettes as a merge VI. I'm guessing this will work, but I haven't tried it. Quote Link to comment
