Accessing LV Remote Panels using CGI
One of my application is running on the server computer which is located remotely.I was trying to access LabVIEW panels using URL created for the application and i was not able to access the panels and i was getting the following message,
requested VI is not loaded in the memory on the server computer
Can anybody help me regarding this problem
regards,
Naresh.N
QUOTE (NareshN@Capsys @ Nov 6 2008, 03:50 AM)
Are you sure the VI is actually running on the remote machine? Is it a PC or a LabVIEW RT target? If its an RT Target can you ping it or ftp into it? (If you can means you should be able to access its front panel too).
Make sure:
1 Firewalls on both machines allow access
2 VI Server
3 Web Server
are enabled on the Remote machine.
Does the machine you are trying to access with (client) have LV installed on it? If so, try to connect to its remote panel from Operate>Connect to Remote Panel, supplying all details.
Neville.
