pabhon002426 Posted November 8, 2008 Report Posted November 8, 2008 Thing That I want to do design are listing in like a finite state machine Here i use two instrument one is ANRITSU MS 2026A as a RF signal Generator from RF out port having maximum output power 23 dbm and for data acquisition i use 4 3\4 - Digital Multimeter HM 8012 Main task: Here the Anritsu MS2026A is used as a RF signal Generator and its output power level is fixed at 23 dbm. This power will deliver to the TEM cell and it will will generate a uniform field in the TEM cell for a particular frquency. Every time we change the input frquency of the Anritsu and take the probe respone by placing a probe in the TEM cell. This probe is connected to digital multimeter HM 8012. 1. Initialize Instrument () 2. Read Calibration and database file 3. Signal Generator sends frequency and RF level (here RF level is fixed only frequency will change at each iteration) 4. DWELL and read the feedback of the field prob 5. Increase frequency 6. if Current frequency is higer than the stop frequency and go to step 7 7. Stop Here i have also upload the block diagram for this. Quote
Tim_S Posted November 8, 2008 Report Posted November 8, 2008 QUOTE (pabhon002426 @ Nov 7 2008, 11:17 AM) Thing That I want to do design are listing in like a finite state machine I'm not sure what you are asking after reading your post. Is there part of this you want help with? All of it? Some particular point? Tim Quote
pabhon002426 Posted November 8, 2008 Author Report Posted November 8, 2008 QUOTE (Tim_S @ Nov 7 2008, 07:09 PM) I'm not sure what you are asking after reading your post. Is there part of this you want help with? All of it? Some particular point?Tim all of it Quote
Anders Björk Posted November 8, 2008 Report Posted November 8, 2008 QUOTE (pabhon002426 @ Nov 7 2008, 08:24 PM) all of it Break down the problem, write code (VI) for the voltmeter first, test your code, improve it, ok?, then do the VI for the signal generator etc... Learn.. If you have specific problems ask here. If you have low labview knowledge read some good bok or look at labview for dummies atleast if it is still on the internet... Quote
