get xy waveform last value
cromax
hello
I want to use get xy waveform function with the Aim to get the last value of waveform acquisition.
What index i can use in this function?
I read in a help that if i don't use any index i get the o component and not the last.
It's true?
thank you
QUOTE (cromax @ Nov 27 2008, 06:42 PM)
  Quote
hello
It's true?
thank you
Last index = length - 1
And yes, if you don't wire any index, you'll get the first result (index=0).
Thanx NevilleD,
That's really neat and faster and more compact than always going with "Index array"("Array Length" -1). I tried it and was surprised to see it working, even if you change the length of it. If you do that, without an index, it takes the "n" last elements in the array. LabVIEW Help file specifies this behavior. Neat!
I'll reuse that one for sure.
Olivier
QUOTE (normandinf @ Dec 1 2008, 12:57 PM)
  Quote
It is easier, although my benchmarks show it's 3 times slower than the "Index array"("Array Length" -1) way. Averaged on a million operations with 100-element array, using "Delete from Array" resulted in a 7.2us execution time per loop, compared to 2.25us per loop for the "Index Array" method. Actually, other methods are faster too:
Based solely on execution speed, you should use the IndexArray(Length-1) method... but reversing the array is not bad for a 100-element array.
Sure, its the lazy programmer's way to get at the final element. It also conserves valuable block diagram space; and with multi-core processors, it shouldn't make too much of a difference. That being said, if I want a routine to be really fast, I use the Index array with (N-1) as input.
It might be slower because a buffer might need to be allocated for the remaining N-1 element array. Did you have that wired as well?
Neville.
QUOTE (Neville D @ Dec 1 2008, 04:16 PM)
  Quote
There were no difference (or sub microsecond) for unwired index or 0-wired.
And I totally agree with your usage assessment. I, too, am lazy most the time... :P
EDIT: I didn't try wiring the DeleteArray index with (length-1)... (If we did, then the output changes from Scalar to Array)
