communication between labview 8.2 and ms acces 07
I am student Engineer and i am in my last year. For my thesis i have to install a power supervision on a machine. This is measured by a Schneider Elektric PM710 and now i have to make a program that writes some values that i get out of this component every few seconds to a accessdatabase so i can interpret them later. I hope somebody can help me.
QUOTE (stefvg @ Dec 16 2008, 08:01 AM)
Basically the process is to use ADO (ActiveX Data Objects) to connect to the *.mdb file. If you are familier with using ActiveX the process is very straightforward. Plus there are free VIs available (check the NI user forum).
Mike...
QUOTE (MikePorter @ Dec 22 2008, 07:01 AM)
Mike...
It is also possible to use the Database Connectivity Toolkit that NI makes available. Like other toolkits there is a charge involved so check with NI about specifics.
