Jeffrey Habets Posted January 4, 2009 Report Share Posted January 4, 2009 I would like to encapsulate my FPGA access in a class, but it seems LV can't handle it. If I have one (or more) FPGA interface nodes in one of my methods, save and close the project and open it up again, LV crashes in exec.cpp line 1704. I reported the problem to NI and am waiting for their response, but in the meantime I'm curious if someone else has bumped into this problem. I'm using LV8.6. Quote Link to comment
LAVA 1.0 Content Posted January 6, 2009 Report Share Posted January 6, 2009 QUOTE (Jeffrey Habets @ Jan 3 2009, 04:28 PM) I would like to encapsulate my FPGA access in a class, but it seems LV can't handle it. If I have one (or more) FPGA interface nodes in one of my methods, save and close the project and open it up again, LV crashes in exec.cpp line 1704.I reported the problem to NI and am waiting for their response, but in the meantime I'm curious if someone else has bumped into this problem. I'm using LV8.6. Jeffrey, I had not tried this before, but decided to give it a whirl as I see LV classes being a great interface tool for the FPGA. I put together a simple class to talk to my FPGA, but did not run into the problem you described. I have attached my project files for reference. Can you give these a try and let me know what happens? http://lavag.org/old_files/post-3370-1231200448.zip'>Download File:post-3370-1231200448.zip Quote Link to comment
Jeffrey Habets Posted January 7, 2009 Author Report Share Posted January 7, 2009 QUOTE (LV_FPGA_SE @ Jan 6 2009, 01:08 AM) I had not tried this before, but decided to give it a whirl as I see LV classes being a great interface tool for the FPGA. I put together a simple class to talk to my FPGA, but did not run into the problem you described.I have attached my project files for reference. Can you give these a try and let me know what happens? Download File:post-3370-1231200448.zip Thanks for testing this. I tried your project, and it loads fine here.. No problem. So it seems my problem is probably not (only) class-related. Maybe it has also to do with the kind of FPGA-target configuration, I don't know. I've attached the stripped-down project that reproduces the problem. This is also the project send to the NI AE and now under investigation as CAR#: 139277. Note that my classes are GOOP3 (Endevo) which is basically a LV native class with some extra. The problem isn't in the GOOP3 framework for sure, since I can also reproduce it with a LV native class in this same project. The project as attached will open without a problem because the FPGA interface nodes are commented out. To reproduce the problem, open FPGA0_DAQ.lvclass:FPGA0_DAQ_Create.vi (under Hardware) and enable the stuff that is now disabled. Save the VI and project, then close and re-open the project. Download File:post-906-1231252734.zip Quote Link to comment
Jeffrey Habets Posted January 9, 2009 Author Report Share Posted January 9, 2009 The problem will be resolved in a next LabVIEW release.. NI Offered me two possible workarounds of which I used the second one and this works for me: Set resource\Framework\Providers\lvrio\crio.llb\_nicrio_getModuleXML.vi and _nicrio_getModuleXMLForRSI.vi to non-reentrant. Since these are password-protected VI's that's not really an option for normal users. Configure the Open FPGA Reference node to use the bitfile instead of the FPGA VI. Quote Link to comment
