problem with lvm file
hi all,
attach is my lvm file. in the follwing part:
0.000000 27.374516 3:19:28 PM
0.953125 27.374516 3:19:29 PM
1.937500 27.374516 3:19:30 PM
2.953125 27.374516 3:19:31 PM
i want to ask what is the value 0.000000, 0.953125, 1.937500, 2.953125 stand for? can it be disable? my block diagram is same as in previous post add timer control to my program http://forums.lavag.org/adding-timer-contr...ram-t12829.html. one more question is the value in the middle is my temperature sensor value. how to change it to save only in two decimal place?
hi all,
QUOTE (mic_k86 @ Jan 15 2009, 08:49 AM)
I assume the first column is the timer value at which the temperature is measured. Can you post your VI so that we can advise better ?
When using the express VI "write to measurement file" I'm not sure of the best way to set the number of decimal.. :unsure:
