mic_k86 Posted January 16, 2009 Author Report Posted January 16, 2009 hi all, my labview project just contain few button and text box in control panel. after i making it in exe file, and running the exe file, i found that if i maximize the exe windows, there will be many empty place at the side. so i plan to fixed the size of exe form. how to do that? Quote
mic_k86 Posted January 16, 2009 Report Posted January 16, 2009 hi all, my labview project just contain few button and text box in control panel. after i making it in exe file, and running the exe file, i found that if i maximize the exe windows, there will be many empty place at the side. so i plan to fixed the size of exe form. how to do that? Quote
Antoine Chalons Posted January 16, 2009 Report Posted January 16, 2009 QUOTE (mic_k86 @ Jan 15 2009, 08:54 AM) hi all,my labview project just contain few button and text box in control panel. after i making it in exe file, and running the exe file, i found that if i maximize the exe windows, there will be many empty place at the side. so i plan to fixed the size of exe form. how to do that? Hello, You can edit the properties of you main VI (ctrl + i) in the category "Window Appearance", then "Customize" and you have many different options among which : "Allow user to resize window", this has to be done for each VI that will be visible to the user. You can also set these options programmatically using property nodes : http://lavag.org/old_files/monthly_01_2009/post-7452-1232007949.png' target="_blank"> Hope this helps Quote
