I need your help with Vision in Labview
I use the Vision Builder and convert to Labview file for use with control
the
servo motor. But I have some problem as shown below
1.When I finish the programm with Vision Builder I convert to Labview file
,in this state I don't found the problem
2.I cannot run Labview file because it has some problem about there are
not found some of the command such as "IMAQ create" in the Block diagram and
it is shown the "?" in the block ,then I don't sure that I'm install the programm
right?
3.When I open Labview file again It was asked for "IMAQ image.ctl" and any
of
the file with type ".ctl,.ctt" I don't know where can I find?
4.When I use Labview to manage with the Image I input the command "IMAQ
Build
Coordsys" then the programm asked for many of the "IMAQ image.ctl" too.
5.My device is :
- Camera:Busler scA640-70fm
- NI pci 6221
- NI pci 8254r
My programm is:
Labview 8.5
Vision Builder AI 3.0.1
Vision assistant 8.0
Vision aquisition 8.2.2
What Can I manage my problem?
I'm really need your help
Help me please!!!
the
right?
of
Build
5.My device is :
- NI pci 6221
- NI pci 8254r
My programm is:
Labview 8.5
Help me please!!!
QUOTE (Poom-Thailand @ Jan 16 2009, 11:49 AM)
the
right?
of
Build
5.My device is :
- NI pci 6221
- NI pci 8254r
My programm is:
Labview 8.5
Help me please!!!
The "IMAQ image.ctl" file is located here : C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\vision\Image Controls.llb\IMAQ image.ctl
The "IMAQ create" function is located here : C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\Vision\Basics.llb\IMAQ Create
Hope this helps.
the
right?
of
Build
5.My device is :
- NI pci 6221
- NI pci 8254r
My programm is:
Labview 8.5
Help me please!!!
Hope this helps.
QUOTE (Antoine Châlons @ Jan 16 2009, 06:04 PM)
Hope this helps.
I see in that folder but I cann't find "Image Controls.llb\IMAQ image.ctl" I don't sure is it cause mismatch about the version of the program?
Hope this helps.
QUOTE (Poom-Thailand @ Jan 17 2009, 05:05 AM)
If you have installed the Vision Development Toolkit from the LabVIEW DVD go into Add/Remove Programs Control Panel and do a repair of your install. If you haven't yet done so then install that package.
Rolf Kalbermatter
