Dark lines on Tab Control
I've noticed these dark lines in my tab controls in Linux. There are a couple of colours that seem to hide the lines completely. But most don't.
I'm curious if anyone else has noticed this. Is there any workaround?
QUOTE (pallen @ Jan 25 2009, 06:11 PM)
What the? Can you upload the VI? I wonder if it's a screen redraw issue - if you minimize and the restore the window, do they go away?
QUOTE (crelf @ Jan 25 2009, 08:53 PM)
They don't go away. :(
Linux.... not sure if this will help...
On Windows I would check the color depth first and then gradually back-oof on the graphic accelerator options to see if the problem goes away.
Sorry but that is all I can offer,
Ben
Yup. Same thing here too. Tab Controls from VIs made in Windows display this way too. I'm just not sure if it's the OS or *my* OS.
QUOTE (pallen @ Jan 26 2009, 01:43 PM)
Most likely a graphics driver issue. LabVIEW does direct X Windows drawing and depending on the graphics driver used this might cause such issues. Try experimenting with the graphics driver settings, such as color depth, acceleration and such.
