When should Tasks be used in a DAQmx application?
WGMres
QUOTE (crelf @ Feb 8 2009, 03:17 PM)
Then you're going to love it even more when you find out that you can (and arguable should) do all those good things in the project:
Interesting. I'm curious what the advantages are in adding tasks this way as opposed to using MAX.
QUOTE (pallen @ Feb 9 2009, 10:43 AM)
I tried to come up with an intelligent list of the benefits of doing it this way, but it all came down to, well, your DAQmx settings are saved at the project level instead of the system level. The channel and task settings that would normally be in your system mce file are instead in your lvproj file - a much better idea IMHO.
