layering
Kubo
QUOTE (Kubo @ Feb 24 2009, 11:14 AM)
I made the terminal transparent but I cant figure out how to make it so the image is under the terminal instead of on top.
I'm not sure that I understand what you mean by "terminal" - can you post a screen shot on what you're talking about?
I want an image in the background of a terminal. I made the terminal transparent but I cant figure out how to make it so the image is under the terminal instead of on top. I read somewhere that its in the Edit menu but I cant find it.
I am working with 8.6.
I'm lost as well but I'll guess.
On your button bar (the bar with the run arrow) the far right button called "Reorder" may be what you want (after you select the object).
