XControl... just not getting it
OK, so I wrote a very simple (and useless) XControl. All it should do is take a numeric and copy it to a string.
From the fresh XControl, the only thing I changed was Facade.vi. I added a Value Changed event for the numeric, which transfers its value to Data Out, and sets Action.Data Changed? = TRUE.
I dropped the XControl on a new VI, and changed the numeric. I was expecting the 'Data Change' event to fire right after and update the string value, but the 'Data Change' event never executes.
I feel like I'm missing something obvious...
OK, Thanks guys. I got thrown by the built-in comment
QUOTE
  Quote
If you modify Data Out or
Display State Out set the
appropriate Boolean in Action
to TRUE.
I thought that would mean that the Data Changed event case would get executed, but now it makes sense; you never get anything for free.
I had read the wiki page, but if your understanding is broken like mine was, it doesn't point you back in the right direction. I'll add some text if I can figure out what would have helped me.
So the underlying issue is that, for the control I'm really working on, any number of things can happen, and I just want to repaint the whole display whenever the data changes or the state changes or any of the auxiliary facade controls change. Where is the best place to put that code such that it's easy to invoke it from various points on the facade block diagram?
QUOTE (jdunham @ Mar 6 2009, 04:57 PM)
  Quote
What I normally do is add a field to the XControl's state as a commander.
In the timeout event of the XControl I read the command state and redraw if necessary.
This can even be done from an XControl property or method.
Ton
QUOTE (Ton @ Mar 6 2009, 09:01 AM)
  Quote
Fantastic, thanks!
  • 2 years later...
