Set "Editor Options"
In the VI properties, under "Editor Options" we can choose the default style for create controls and indicators. This setting can be different for each VI, by default, when we create a new VI this property will match what you have set in your LabVIEW options.
Now.. for one VI can we set this property programmatically ?
My use case is simple I got a fairly big code from a college, and I'd like to load all the VIs in memory and run a VI that would modify this property for each VI.
