LabVIEW-compatible hardware in hobbyist price range
Sparkette
Is there any USB hardware compatible with LabVIEW which can let me get a taste of the hardware interfacing features in LabVIEW that I don't need to shell out hundreds of dollars for? There's got to be something in the sub-$50 price range which can be controlled by LabVIEW over USB. Any ideas?
Helo flarn,
You can control any USB device with VISA (http://zone.ni.com/devzone/cda/tut/p/id/4478). Works the same as any other programming environment.
-Justin
oops posted too early :)...
If you take a look at the link, it is equivalent to any other bus IO in LabVIEW.
Why do you want to take a trial of USB IO in LabVIEW? Seems like a lot of effort. Also, what kind of devices are you ultimately trying to interface, custom devices or commercial devices (i.e. a uC or a webcam)?
Best of luck,
-Justin
You can even do it for free.
The soundcard, parallel and serial port are accessible in Labview, and can be used as I/O.
For example, with the microphone input you can measure AC signals, like the speed af a car using the tacho signal
QUOTE (RalcoBe @ Mar 30 2009, 10:31 AM)
Confirm. Some time ago I made simple metal detector and distance sensor using piece of copper wire and two jack plugs. I winded wire around a pencil making a coil and was generating sinusoindal signal through headphones output and measuring responce with microphone input.
There is also a number of cheap "osciloscope cards" working with sound card (around few $) - making such a play safer for sound card
Good call on the simulated daqmx tasks.
Also look at the TCP/IP and UDP examples in the NI ExampleFinder. Those can provide hours upon hours of fun and amusement :).
-Jusitn
