crelf Posted July 1, 2009 Report Posted July 1, 2009 Name: Convert between ASCII and Unicode Submitter: crelf Submitted: 30 Jun 2009 File Updated: 17 Apr 2010 Category: General Version: 1.1.0 LabVIEW Version: 8.2 License Type: Creative Commons Attribution 3.0 Copyright © 2006, Christopher G. Relf All rights reserved. Author: Christopher G. Relf christopher_relf@yahoo.com Distribution: This code was downloaded from: http://forums.lavag....odule=downloads Description:: Convert between ASCII and Unicode Version History: 1.1.0: Faster ASCII to UNicode alogrithm 1.0.1: Bug Fix - Removed increment in "Convert Unicode to ASCII.vi" 1.0.0: Initial release of the code. Click here to download this file 1 Quote
majidebru Posted August 31, 2012 Report Posted August 31, 2012 Hi all I used the Persian language in my application I use a program Convert between ASCII and Unicode V 1.0.0. But when I run the application on the destination computer, I have two problems: 1 - Words should be from right to left, but there are from left to right 2 - Letters should be sticking together, but there are separated How do I solve these problems my labview version is 2009. in my computer , i write useunicode=true in "labview.ini" Grateful Quote
Ton Plomp Posted August 31, 2012 Report Posted August 31, 2012 I think that those setting (orientation and direction) are properties of the string control. It's not something that should be dealt with in such a tool. Ton Quote
asbo Posted August 31, 2012 Report Posted August 31, 2012 Your Windows regional settings are configured for RTL, correct? Quote
majidebru Posted August 31, 2012 Report Posted August 31, 2012 I think that those setting (orientation and direction) are properties of the string control. It's not something that should be dealt with in such a tool. Ton i don't find any setting for orientation and direction. may you show me. Your Windows regional settings are configured for RTL, correct? destination computer doesn't have any font! i don't have Windows CD. Can i install my font(Persian Font)? Quote
asbo Posted August 31, 2012 Report Posted August 31, 2012 destination computer doesn't have any font! i don't have Windows CD. Can i install my font(Persian Font)? This article describes what I was referring to: KMKB0041: HOWTO: Configure Windows for right-to-left languages such as Arabic, Farsi or Hebrew Quote
majidebru Posted August 31, 2012 Report Posted August 31, 2012 I know how to Configure Windows for right-to-left languages such as Arabic, Farsi or Hebrew but when i ticked "Install files for complex script and right-to-left languages (including Thai)" , i should insert windows CD in CD-ROm and i don't have Windows CD. Quote
asbo Posted August 31, 2012 Report Posted August 31, 2012 Then find a Windows CD? Or search to see if you can download something from Microsoft to install the languages. 1 Quote
Yair Posted September 2, 2012 Report Posted September 2, 2012 LabVIEW has no official support for right-to-left languages. I can say that it sort of works with Hebrew (in ASCII) if you know what you're doing, but I haven't tried with Arabic, so I don't know about connected letters. In any case, even when it does work, as soon as you add in anything which isn't part of the R2L set (such as a comma or a hyphen or a number), the display gets reversed. If you're on Windows, you can try using a .NET or ActiveX control and using the rich text box. That should display the text correctly. 2 Quote
