paramesium Posted April 15, 2009 Report Posted April 15, 2009 halo ...this is part of my programme everything is working fine including the saving and open part but heres the problem... when i trying to cancel the save... it show me the error message as below Quote
bmoyer Posted April 15, 2009 Report Posted April 15, 2009 QUOTE (paramesium @ Apr 14 2009, 09:45 AM) halo ...this is part of my programme everything is working fine including the saving and open part but heres the problem... when i trying to cancel the save... it show me the error message as below This is probably caused by the Automatic Error Handling which only takes effect when running in the development environment (when running the source code). Either wire up the error cluster to properly handle this error or turn off automatic error handling (from the "Tools" menu, select "Options..." the click "Block Diagram" and then uncheck the "Enable automatic error handling dialogs" checkbox). Quote
paramesium Posted April 15, 2009 Author Report Posted April 15, 2009 thanx bmoyer... dear moderator... i am sorry ... i just realise i posted in the wrong section...please help me move this topic if possible thank you Quote
asbo Posted April 15, 2009 Report Posted April 15, 2009 If you want to filter the canceled error, wire both the error cluster and the cancelled boolean to a stacked case structure - the first layer checks if there was an error, the second checks if the dialog was cancelled. If both are true, just wire out a default error cluster and you're set. Quote
ASTDan Posted April 15, 2009 Report Posted April 15, 2009 Yes that is an annoying little thing about the File Dialog VI. Here is one I have developed that also asks if you want to overwrite if the file if it already exists. I also have my automatic Error handling turned off. Dan Download File:post-8614-1239726359.vi Quote
lightworker Posted April 15, 2009 Report Posted April 15, 2009 Hi, I would just use a case structure with the cancelled option (file dialog icon) wired to it so that you can provide an alternative path if the save operation is cancelled. I think at the moment the dataflow has nowhere to go when you cancel - hence the error message. Same thing happened to me about 2 weeks back. Lightworker QUOTE (paramesium @ Apr 14 2009, 03:45 PM) halo ...this is part of my programme everything is working fine including the saving and open part but heres the problem... when i trying to cancel the save... it show me the error message as below Quote
