Value of the Network Shared Variable when the computer turns off
jangel22
Hi folks  :)
I'm working with NSV deployed in two computers (lets call them A and B), but I want to be able to make the value of the NSV in B false when the program exits in A or when this computer turns off.
Any idea of how make this?
PS. Excuse my english.
Thanks in advance
There are a few ways you can do this.
First way
Make the program in A write "true" to the NSV when it starts, and make it write "false" before it quits.
This is simple, but there is one disadvantage: If the program in A doesn't quit properly, then the value will stay "true". For example, if computer A loses power, the program stops running but it can't write "false".
Second way
Make the program in A write a value to the NSV every second. The program in B doesn't check the value, but it checks the timestamp. If the timestamp doesn't change for 5 seconds, then B sets a local flag to "false".
If computer A is hosting the NSV and it is not running, then B should get an error when it tries to read the variable.  With an error, I would expect the default values.  But it may be the last read value.  But you should be able to look for the error.
