How to assign a different color to each line of a String Indicator ?
Hi guys,
Would it be possible to assign a different color to each line of String in a String Indicator ?
The only thing a know is that when you try to modify through a property node it changes all the lines of the string indicator ...
This might be possible but how ?
regards
You need to select the text you want to color before applying the new color. The string control has two properties for the selection start and end points. I don't remember if there's a separate property for the selected text color, but I'll leave you to work out the details.
First, thanx for your answer. I did try to use the selection option of the String Indicator's property node. The problem is can't make it work.
I added the elements
"Text.SelStart" '2' (2 means the start of selection is the second Byte if i'm not wrong)
"Text.SelEnd" ' 5'
"Text.TextColor" '0' (for black)
for example. The thing is I don't see any change in the String indicator.
Hi again,
Sorry I might be a fool but the link you previously posted isn't working for me, I'll look for the tutorial anyway.
While I'm here I just want to know why the use in my VI of the FontColor modification doesn't work ... You guys are so clever that you may find the origin of the problem ...
Here is the picture of my VI
thanks a lot
I've started a new thread because I think it's a bug. But let's hear what the others have to say about this: it could be intended behavior.
To answer you problem directly, I think it has to do with the fact that whenever you append a string, the whole string will revert to it's last color setting and dump all font color info you've set.
Follow this link to get a hint at what I'm saying.
Hi again,
thanks a lot
What is the value of the 'reads' variable at this state? can you probe it to make sure there is no funny value for it before adding another 85 to it?
Hmm yeah, I checked these read values and semmed to be ok ... but it's not so important because I put this value just to see if there was a different color at a point in the String. I tried with a lot of different values.
Listbox seems to be great for this purpose... I will check it out !
Thanks for your help guys.
PS: Sorry for the late answer, I did put this feature aside for a moment and worked on the rest of my project.
