labviewnoob Posted July 22, 2009 Report Share Posted July 22, 2009 is there a way to make the led display 4 different colors when the condition is met? i found an example using property node but i do not understand it. Quote Link to comment
Kurt Friday Posted July 22, 2009 Report Share Posted July 22, 2009 Another way is to just use a pic ring, example attached. 4ColorLED.ctl Quote Link to comment
Yair Posted July 22, 2009 Report Share Posted July 22, 2009 Or to customize a color box to look like a LED. You should be able to find an example if you search the NI forums for "color LED". Quote Link to comment
labviewnoob Posted July 23, 2009 Author Report Share Posted July 23, 2009 (edited) Hi. Thanks sciware for the ctl file. but i do not know how i could integrate it into my main vi. do you mind telling me how i could use the pic ring? i have started a thread regarding the color led in ni forum yesterday too. Edit*: my groupmate has managed to get the results using the event structure. http://forums.ni.com/ni/board/message?board.id=170&thread.id=425860 Edited July 23, 2009 by labviewnoob Quote Link to comment
Kurt Friday Posted July 23, 2009 Report Share Posted July 23, 2009 Hi. Thanks sciware for the ctl file. but i do not know how i could integrate it into my main vi. do you mind telling me how i could use the pic ring? i have started a thread regarding the color led in ni forum yesterday too. Edit*: my groupmate has managed to get the results using the event structure. http://forums.ni.com...hread.id=425860 Yair has a good point, have a look at the colorbox option. To see how to use the LED.ctl just drop it onto your front panel, make it an indicator and then wire a numeric control to it. You will see that. 0 = Red 1 = Blue 2= Dark Green 3 = Yellow So your 4 states or colors map to a numeric value. To make the LED.ctl I started with a classic pic ring and then copied images of a Boolean LED that I had painted different colors. You can get the images of the Boolean LED by editing the boolean control and then copying the image component. Then paste it into the pic ring. For more detail about editing controls have a search on the NI site. I'm not sure about your other issue, the link you have posted appears to be broken Quote Link to comment
labviewnoob Posted July 23, 2009 Author Report Share Posted July 23, 2009 Yair has a good point, have a look at the colorbox option. To see how to use the LED.ctl just drop it onto your front panel, make it an indicator and then wire a numeric control to it. You will see that. 0 = Red 1 = Blue 2= Dark Green 3 = Yellow So your 4 states or colors map to a numeric value. To make the LED.ctl I started with a classic pic ring and then copied images of a Boolean LED that I had painted different colors. You can get the images of the Boolean LED by editing the boolean control and then copying the image component. Then paste it into the pic ring. For more detail about editing controls have a search on the NI site. I'm not sure about your other issue, the link you have posted appears to be broken hi thanks alot for telling me how to use the led.ctl. the link is the thread which i started in the ni forum. Quote Link to comment
Yair Posted July 23, 2009 Report Share Posted July 23, 2009 i have started a thread regarding the color led in ni forum yesterday too. Funny. I could have sworn I said "search". Quote Link to comment
horverno Posted July 23, 2009 Report Share Posted July 23, 2009 i had almost the same problem, i solved it with a string indicator which has a background color property i can change it's not a led, but for me was ok.. the code is simple, i hoipe it helps i had almost the same problem, i solved it with a string indicator which has a background color property i can change it's not a led, but for me was ok.. the code is simple, i hoipe it helps colors.vi colors.vi Quote Link to comment
TobyD Posted July 23, 2009 Report Share Posted July 23, 2009 I just use the Boolean property node Colors[4]. You can use color box constants in the cluster rather than integers so it's easy to choose whatever color you desire (see image). If you don't care about the Boolean value and strictly want a color indicator then you only have to set the first color. --- Quote Link to comment
labviewnoob Posted July 24, 2009 Author Report Share Posted July 24, 2009 Thanks all. changing the background color of the string indicator is cool. i will see how i can integrate it into my project. Quote Link to comment
