LV2009 Build exe fail if VI has no front panel
LV2009 Build exe fail if VI has no front panel. Anyone notice that?
No such problem early versions.
Error: Revision Number no available.
George
Do you mean if any VI in the project doesn't have a front panel or the top level VI? Either one I would consider a bug, but one more severe than the other.
How do you have a VI with no FP? I thought you only get those after building an EXE.
Do you build an EXE and then reuse the VI from that EXE?
There is a way to remove front panel and diagram before build into exe.
Check the script forum.
George
