Programmatically create separate windows
Can a VI create a new window programmatically, a new window which can float around anywhere?
I am trying to finish a little program which can post a note on the monitor, an easy way to record some ideas. Each note is in a separate new window, and can be updated or deleted. (Yes, the program is available for free download somewhere online, but I wish to have a LV version).
Maybe this is not a User Interface problem. It's more like a OOP, treating each note an object of the Class NOTE, and .....
An easy way to accomplish this is through VI server and the usage of Re-entrant Front Panels or the use of *.vit 's
First step is to make a VI that will be cloned over and over for each new note.
Flag the open with option 0x08 and it will open a new VI with each call.
<object width="1020" height="628"> <param name="movie" value="http://content.screencast.com/users/NJKirchner/folders/Jing/media/5fc68419-458d-495e-a4fe-582888c1dcf6/jingh264player.swf"></param>'>http://content.screencast.com/users/NJKirchner/folders/Jing/media/5fc68419-458d-495e-a4fe-582888c1dcf6/jingh264player.swf"></param> <param name="quality" value="high"></param> <param name="bgcolor" value="#FFFFFF"></param> <param name="flashVars" value="thumb=http://content.screencast.com/users/NJKirchner/folders/Jing/media/5fc68419-458d-495e-a4fe-582888c1dcf6/FirstFrame.jpg&containerwidth=1020&containerheight=628&content=http://content.screencast.com/users/NJKirchner/folders/Jing/media/5fc68419-458d-495e-a4fe-582888c1dcf6/2009-12-07_1054.mp4"></param> <param name="allowFullScreen" value="true"></param> <param name="scale" value="showall"></param> <param name="allowScriptAccess" value="always"></param> <param name="base" value="http://content.screencast.com/users/NJKirchner/folders/Jing/media/5fc68419-458d-495e-a4fe-582888c1dcf6/"></param>'>http://content.screencast.com/users/NJKirchner/folders/Jing/media/5fc68419-458d-495e-a4fe-582888c1dcf6/"></param> <embed src="http://content.screencast.com/users/NJKirchner/folders/Jing/media/5fc68419-458d-495e-a4fe-582888c1dcf6/jingh264player.swf" quality="high" bgcolor="#FFFFFF" width="1020" height="628" type="application/x-shockwave-flash" allowScriptAccess="always" flashVars="thumb=http://content.screencast.com/users/NJKirchner/folders/Jing/media/5fc68419-458d-495e-a4fe-582888c1dcf6/FirstFrame.jpg&containerwidth=1020&containerheight=628&content=http://content.screencast.com/users/NJKirchner/folders/Jing/media/5fc68419-458d-495e-a4fe-582888c1dcf6/2009-12-07_1054.mp4" allowFullScreen="true" base="http://content.screencast.com/users/NJKirchner/folders/Jing/media/5fc68419-458d-495e-a4fe-582888c1dcf6/" scale="showall"></embed> </object>
I don't know how to make the needles do a circular motion, unless the controls on the front panel have a angle property to modify. But they don't.
The needle part is actually fairly easy. Use a "Gauge" control and set all but the needle color to be Transparent.
Here is an example I did up real quick.
I used 3 gauges one for the minute hand, one for the hour hand and one for the numbers. Once running right the clock face and select Exit to stop.
Ryan
Clock.zip
Sorry, but can you explain a little bit how you made the note.vi movable? It seems like something about register user event, but I cannot figure out how to implement it. Thanks again.
This should help
DraggableFP.zip
<object width="786" height="600"> <param name="movie" value="http://content.screencast.com/users/NJKirchner/folders/Jing/media/e383f68c-f6e5-4966-a51b-45a46b0d8724/jingh264player.swf"></param>'>http://content.screencast.com/users/NJKirchner/folders/Jing/media/e383f68c-f6e5-4966-a51b-45a46b0d8724/jingh264player.swf"></param> <param name="quality" value="high"></param> <param name="bgcolor" value="#FFFFFF"></param> <param name="flashVars" value="thumb=http://content.screencast.com/users/NJKirchner/folders/Jing/media/e383f68c-f6e5-4966-a51b-45a46b0d8724/FirstFrame.jpg&containerwidth=786&containerheight=600&content=http://content.screencast.com/users/NJKirchner/folders/Jing/media/e383f68c-f6e5-4966-a51b-45a46b0d8724/2009-12-08_1805.mp4"></param> <param name="allowFullScreen" value="true"></param> <param name="scale" value="showall"></param> <param name="allowScriptAccess" value="always"></param> <param name="base" value="http://content.screencast.com/users/NJKirchner/folders/Jing/media/e383f68c-f6e5-4966-a51b-45a46b0d8724/"></param>'>http://content.screencast.com/users/NJKirchner/folders/Jing/media/e383f68c-f6e5-4966-a51b-45a46b0d8724/"></param> <embed src="http://content.screencast.com/users/NJKirchner/folders/Jing/media/e383f68c-f6e5-4966-a51b-45a46b0d8724/jingh264player.swf" quality="high" bgcolor="#FFFFFF" width="786" height="600" type="application/x-shockwave-flash" allowScriptAccess="always" flashVars="thumb=http://content.screencast.com/users/NJKirchner/folders/Jing/media/e383f68c-f6e5-4966-a51b-45a46b0d8724/FirstFrame.jpg&containerwidth=786&containerheight=600&content=http://content.screencast.com/users/NJKirchner/folders/Jing/media/e383f68c-f6e5-4966-a51b-45a46b0d8724/2009-12-08_1805.mp4" allowFullScreen="true" base="http://content.screencast.com/users/NJKirchner/folders/Jing/media/e383f68c-f6e5-4966-a51b-45a46b0d8724/" scale="showall"></embed> </object>
I'm a bit curious. Why did you use the timeout event with a timeout of 10 ms timeout instead of the mouse move event?
I'm merely curious. I want to learn from the masters.
Good question my friend.
And it is for this reason, it doesn't work as well because if the person moves the mouse faster than LV can move the panel then everything gets out of whack and you lose the drag.
I started by doing it that way.
I actually don't like having to revert to polling but it was the only way to get consistent, repeatable and responsive interaction.
On a very fast PC w/ nothing going on I would imagine that you 'might' not notice it. But if you were to change the algorithm and move the mouse quickly, you'll find that you lose the drag w/ out much effort.
