Francois Normandin Posted January 11, 2010 Report Posted January 11, 2010 Name: UI Tools expansion pack: Vista style Submitter: Francois Normandin Submitted: 10 Jan 2010 Category: User Interface LabVIEW Version: 2009License Type: BSD (Most common) UI Tools Expansion pack: Vista Style controls v1.1.0.4 Copyright © 2009-2015, François Normandin. (LabVIEW controls) Copyright © 2003-2004 David Vignoni. (NUVOLA ICON THEME FOR KDE 3.x) All rights reserved. Author:François Normandin Contact Info: Contact via PM on www.lavag.org LabVIEW Versions: Created with LabVIEW 2009 Dependencies: Description: This package contains Vista-style buttons without text. Includes: - Set of Vista-style controls - Based on Nuvola icons (see attached LGPL license) Instructions: After installing package with VIPM, refresh palettes if VIPM is not set to refresh automatically. Use palettes. Known Issues: Acknowledgements: David Vignoni (Icon King) for the Nuvola Icon Theme Change Log: v1.1.0.4: Fixed palettes with "?" icons due to control name collisions v1.1.0.2: Migrated package to VIP, Moved controls to vi.lib, LV 2009 v1.0.1: Removed a menu file that showed up incorrectly in the functions palette. Linked the Point & Double Point Arrows palettes to the Arrow subpalette. v1.0.0: Initial release of the code. (8.6) License: Distributed under the BSD license. Nuvola icons are LGPL licensed. Keep Nuvola Icons license with distributions. Support: If you have any problems with this code or want to suggest features: please go to www.lavag.org and Navigate to the discussion page. Distribution: This code was downloaded from the LAVA Code Repository found at www.lavag.org ============================ Click here to download this file Quote
Mark Balla Posted January 24, 2010 Report Posted January 24, 2010 Certified 1-24-2010 Moved to UI Group Quote
Ton Plomp Posted March 28, 2011 Report Posted March 28, 2011 Certified 1-24-2010 Moved to UI Group François, could you alter the set to move the boolean text ouside of the boolean image? I have created a screencast on this issue. <object id="scPlayer" width="632" height="323" type="application/x-shockwave-flash" data="http://content.screencast.com/users/TonPlomp/folders/Jing/media/ecf08f20-602b-446c-8a5e-73f7e46c7ce7/jingswfplayer.swf" > <param name="movie" value="http://content.screencast.com/users/TonPlomp/folders/Jing/media/ecf08f20-602b-446c-8a5e-73f7e46c7ce7/jingswfplayer.swf" /> <param name="quality" value="high" /> <param name="bgcolor" value="#FFFFFF" /> <param name="flashVars" value="thumb=http://content.screencast.com/users/TonPlomp/folders/Jing/media/ecf08f20-602b-446c-8a5e-73f7e46c7ce7/FirstFrame.jpg&containerwidth=632&containerheight=323&content=http://content.screencast.com/users/TonPlomp/folders/Jing/media/ecf08f20-602b-446c-8a5e-73f7e46c7ce7/2011-03-28_1540.swf&blurover=false" /> <param name="allowFullScreen" value="true" /> <param name="scale" value="showall" /> <param name="allowScriptAccess" value="always" /> <param name="base" value="http://content.screencast.com/users/TonPlomp/folders/Jing/media/ecf08f20-602b-446c-8a5e-73f7e46c7ce7/" /> Unable to display content. Adobe Flash is required.</object> Ton Quote
Prabhakant Patil Posted June 9, 2011 Report Posted June 9, 2011 Hi Can You tell me that How you create the image file to create such control. ? It really work for me. Regards Prabhakant Quote
Francois Normandin Posted June 9, 2011 Author Report Posted June 9, 2011 François, could you alter the set to move the boolean text ouside of the boolean image? Ton Ton, I haven't seen your post before today. I'll work on it, hopefully this week-end. Hi Can You tell me that How you create the image file to create such control. ? It really work for me. Regards Prabhakant Hi Prabhakant, you can install the "Control Class add-on" and it gives you an API for doing what you want. There's also a small program you can launch from the Tools menu that gives you an interface for it. There are some videos in the discussion thread. Quote
Francois Normandin Posted June 10, 2011 Author Report Posted June 10, 2011 François, could you alter the set to move the boolean text ouside of the boolean image? Hey Ton, I made a quick fix VI. It should move the boolean text to thye top right corner, outside of the control. Also, it will unlock the boolean text so you can move it. It will correct the whole VistaStyle Buttons hierarchy in the UI Tools folder. Most likely, I will not have time to make the modification to the set and rebuild the package during the week-end... François. CorrectBoolTextPosition.vi (saved for 8.6) Quote
Ton Plomp Posted November 17, 2012 Report Posted November 17, 2012 Hello François, I have issues with UI tools expansion packs. The controls don't show up in the editor. I see the issue in LV 2011 and LV 2012 This are my installed packages Here's how it looks: Debugging shows that: <vi.lib>\addons\LAVA\controls_lava_lib_ui_tools.mnu should point to: <user.lib>\_LavaCR\UI Tools\ Attached is a fix for this. controls_lava_lib_ui_tools.zip Ton Quote
Francois Normandin Posted November 18, 2012 Author Report Posted November 18, 2012 Ah, indeed. I should probably make a new version of the expansion packs instead, which would install them in the vi.lib/addon directory. Expect the correction in the next version. thanks. Quote
iannicholson Posted March 6, 2015 Report Posted March 6, 2015 Any chance you were able to fix the error? This package still doesn't install properly (in VIPM it claims there is a missing dependency, but it doesn't find one to install). Quote
Francois Normandin Posted April 1, 2015 Author Report Posted April 1, 2015 I should have done that a long time ago. Please follow this link. Quote
iannicholson Posted April 1, 2015 Report Posted April 1, 2015 I should have done that a long time ago. Please follow this link. Better late than never! Thanks for working on this. Quote
