asbo Posted May 17, 2010 Report Share Posted May 17, 2010 (edited) Does anyone know a definition for the behavior of using the equal comparator with strings in aggregate mode? I couldn't find any circumstance where it produced a different output than when in elements mode. Edited May 17, 2010 by asbo Quote Link to comment
Tim_S Posted May 17, 2010 Report Share Posted May 17, 2010 Does anyone know a definition for the behavior of using the equal comparator in aggregate mode? I couldn't find any circumstance where it produced a different output than when in elements mode. Try putting an array into the comparison. The output will switch between a single boolean and an array of booleans as you switch between comparing elements and agregates. Tim Quote Link to comment
crossrulz Posted May 17, 2010 Report Share Posted May 17, 2010 Try putting an array into the comparison. The output will switch between a single boolean and an array of booleans as you switch between comparing elements and agregates. Here's a good example: The results are the same. Quote Link to comment
asbo Posted May 17, 2010 Author Report Share Posted May 17, 2010 Hahaha, I came off way more green than I meant to: specifically with a string, how do the modes differ? Quote Link to comment
Tim_S Posted May 17, 2010 Report Share Posted May 17, 2010 Hahaha, I came off way more green than I meant to: specifically with a string, how do the modes differ? Same answer as with numeric data types. Tim Quote Link to comment
asbo Posted May 17, 2010 Author Report Share Posted May 17, 2010 I don't think you're understanding: is there a difference in behavior of individual versus aggregate comparisons for scalar values? Quote Link to comment
crossrulz Posted May 17, 2010 Report Share Posted May 17, 2010 From the LabVIEW Help, it appears that the two modes only matter when comparing arrays or clusters. Do a search for "Using Comparison functions" or "Setting Comparison Functions to Compare Elements or Aggregates" for the official wording. Quote Link to comment
Djed Posted May 17, 2010 Report Share Posted May 17, 2010 So to be clear, the question/answers are: "With a string, how do the modes differ?" Not at all, the mode setting is ignored. "Is there a difference in behavior of individual versus aggregate comparisons for scalar values?" No, the mode setting is ignored 2 Quote Link to comment
asbo Posted May 17, 2010 Author Report Share Posted May 17, 2010 So to be clear, the question/answers are: "With a string, how do the modes differ?" Not at all, the mode setting is ignored. "Is there a difference in behavior of individual versus aggregate comparisons for scalar values?" No, the mode setting is ignored Yep, that's precisely what I'm looking for. The reason I ask is Jim Kring's Case Insensitive Comparison Mode for String Equality Comparison idea got me wondering if the mode selector did anything for string values - and the fact that it wasn't grayed out when I wired two strings to it made me even more curious. Admittedly, using aggregate mode as a case-insensitive comparison is hardly intuitive functionality, but I can almost twist the logic in my head. Thanks Djed! Quote Link to comment
