lilight Posted August 4, 2010 Report Posted August 4, 2010 Hi I using a musashi dispenser unit with Rs232 for controller pressure and dispense time. I want to write program in Labview for this. They protocol looklike DEFAULT is 19200bps.Data Length: 8 bit Start Bit: 1 bit Stop Bit: 1 bit Parity: None Flow Control: None the Dispense command is stx 04DI_ _(two space) etx the checksum of this command is CF, which is calculate is 00-30("0")-34("4")-44("D")-49("I")-20("SPACE")-20("SPACE")=CF can you guys help me calculate this in labview 8.6 thank you very much Quote
Grampa_of_Oliva_n_Eden Posted August 4, 2010 Report Posted August 4, 2010 Hi I using a musashi dispenser unit with Rs232 for controller pressure and dispense time. I want to write program in Labview for this. They protocol looklike DEFAULT is 19200bps.Data Length: 8 bit Start Bit: 1 bit Stop Bit: 1 bit Parity: None Flow Control: None the Dispense command is stx 04DI_ _(two space)CF etx the checksum of this command is CF, which is calculate is 00-30("0")-34("4")-44("D")-49("I")-20("SPACE")-20("SPACE")=CF can you guys help me calculate this in labview 8.6 VI thank you very much Duplicate post on the Dark side found here. http://forums.ni.com/t5/LabVIEW/checksum/m-p/1204899 Ben Quote
lilight Posted August 4, 2010 Author Report Posted August 4, 2010 hi both of These two topic is posted by myself Duplicate post on the Dark side found here. http://forums.ni.com...sum/m-p/1204899 Ben Quote
hooovahh Posted August 4, 2010 Report Posted August 4, 2010 hi both of These two topic is posted by myself Also another duplicate post from within Lava under the Site Feedback and Support page? In any case just have your bytes in an array then perform an sum function to get the sum of all the bytes. I added your bytes manually and I didn't get 0xCF I got 0x31 and my program attached also gets 0x31. Next time try to attach some code you've already tried but couldn't get working properly. Checksum.vi Quote
lilight Posted August 4, 2010 Author Report Posted August 4, 2010 (edited) hI THIS IS MY checksum programme now i can calaulate he right checksum for example input the 04DI\s\s in code mode can get the CF but i want to design a loop format and use it as a subvi so can you help me with it ? Also another duplicate post from within Lava under the Site Feedback and Support page? http://lavag.org/top...bview-checksum/ In any case just have your bytes in an array then perform an sum function to get the sum of all the bytes. I added your bytes manually and I didn't get 0xCF I got 0x31 and my program attached also gets 0x31. Next time try to attach some code you've already tried but couldn't get working properly. Also another duplicate post from within Lava under the Site Feedback and Support page? http://lavag.org/top...bview-checksum/ In any case just have your bytes in an array then perform an sum function to get the sum of all the bytes. I added your bytes manually and I didn't get 0xCF I got 0x31 and my program attached also gets 0x31. Next time try to attach some code you've already tried but couldn't get working properly. CHECKSUM RIGHT.vi Edited August 4, 2010 by lilight Quote
