CTR Posted August 4, 2010 Report Posted August 4, 2010 I want the user to enter in a control a name. This name will then be use to create a file. I was wandering if it existe some tool to validate that the caractere enter in the name are valid for a file name: no ? for example. Thanks Quote
Popular Post Ton Plomp Posted August 4, 2010 Popular Post Report Posted August 4, 2010 I want the user to enter in a control a name. This name will then be use to create a file. I was wandering if it existe some tool to validate that the caractere enter in the name are valid for a file name: no ? for example. Thanks Yes there is such a VI. That VI is provided by NI. It's located at '\vi.lib\Utility\libraryn.llb\Is Name Multiplatform.vi' in LabVIEW 8.6 and up. For older version look in 'project\llbedit.llb\Is Name Multiplatform.vi' Ton 2 1 Quote
hooovahh Posted August 5, 2010 Report Posted August 5, 2010 Yes there is such a VI. That VI is provided by NI. It's located at '\vi.lib\Utility\libraryn.llb\Is Name Multiplatform.vi' in LabVIEW 8.6 and up. For older version look in 'project\llbedit.llb\Is Name Multiplatform.vi' Ton Thanks Ton another nugget from the VI.lib that could be exposed on the palette. Quote
