"Really" get the class name at run-time
Hi all,
I've searched the Internet and this site, and still didn't find what I was looking for - I guess I'm still a n00b :)
I would really like to get the name of the LV class and do this for all its ancestors.
So it will by a dynamic dispatch method that should return all the class names back to the base class.
Can someone please help me do this?
I've found these two threads:
but they are a bit over my head, to get anything out of them.
Thanks in advance, Mike
HI Mike,
take a look at this API. And find attached the latest version* I use.
There is code for getting the class hierarchy (array of refs or array of paths).
*Disclaimer:
This version 2 of the API is not in the Code Repository yet because I haven't ported it back to 8.6 and haven't retested all methods, so use at own risks. But between you and me, the code for hierarchy is safe.
I also changed the package naming convention since version 1, so you might get a palette conflict if you have both installed at the same time. It might go back to what it was, but most likely, I'll just change the place where the code is stored and where it's installed in the palette to be able to install both. Version 1 becoming "deprecated" simply because I'd rather call it lavag_lvclass_api than normandinf_lvclass_api...
lava_lib_lvclass_api-2.0.0.15.vipFetching info...
  On 8/12/2010 at 1:14 PM, mike5 said:
Thanks, I'll take a look, but what do I do with a VIP file? :blink:
Br, Mike
Download VIPM from jki.net. It's a code reuse package manager. Very useful to distribute code, get code from others and keep track of all your own reuse code, with forward portability between versions.
If you don't want to install a third-party software, PM me and I'll send you a code example.
Thanks again. I "abused" your library to get the LVClassLibrary.ParentClass which I was unable to find in the menu. :worshippy:
I hope you don't mind...
Br, Mike
NOOOO!!!!! :frusty:
LabVIEW Class:Open MethodShort Name: LVClass.Open
Available in Real-Time Operating System: No
Why me?!!!
Does someone know of a solution that works on a Real-Time system?
Br, Mike
Br, Mike
Certainly don't mind...
For your RT problem, you might want to keep the hierarchy in a text file. I remember reading about that here on LAVA where people had the same problem. If not mistaken, Antoine Châlons discussed it. (Might be wrong, but try looking for his posts.)
  On 8/12/2010 at 1:53 PM, mike5 said:
NOOOO!!!!! :frusty:
Why me?!!!
Br, Mike
I am not familiar with RT, but can't you use the Get LV Class Path vi and parse the name from that? Call your parent node vi and have it do the same thing? Each parent could append an array or append a string until you have a complete list?
I can make an example if you need.
Kurt
Kurt
Thanks for the offer, I thought about this as well, but ideally I am looking for a solution that would not require the developer to explicitly call a function in each implementation of the class. But if I'm forced to...
Br, Mike
Anyhoo, I'll post my Windows only solution tomorrow when I'm back at the office for any other unfortunate soul looking for this information...
Mike
Kurt
The "Parent Class" property requires that you open a reference to your library (refnum, not object), which you can't do at runtime, so RT is excluded too.
The Get LV Class from Path primitive works on RT, but the hierarchy can only be found, as stated by AQ in another thread Mike mentioned, through hacking the XML. But this solution has not been posted yet, to my knowledge anyway.
Maybe I misunderstood the OP. I thought he wanted the name of the class and the names of its ancestor classes not the complete hierarchy of a class, that is, not including its children (descendants).
He mentioned using a dynamic dispatch method, so this up the chain hierarchy would be determined at run time.
Did I miss the objective here?
Kurt
Kurt
You understood it better than me. Now that I read it again (and your answer), I agree with you. Thanks for pointing this out.
What's your actual goal? I mean, why do you need the names of the ancestor classes at runtime? What are you trying to achieve? I ask because the reflection stuff works in editor environments, but not runtime environments. We may be able to propose an alternate approach than getting the class name because i doubt you're going to find a satisfactory solution to that exact problem... and we haven't made the reflection API part of the runtime engine because a) it would add to the size of the runtime engine and believe it or not, there is some effort made to keep the thing from becoming ever larger and b) no use cases have ever arisen where someone would need that kind of info in a running application. But perhaps you can explain the use case that would compel this addition in a future version...
  On 8/13/2010 at 5:50 AM, Aristos Queue said:
...and believe it or not, there is some effort made to keep the thing from becoming ever larger...
Anyway, here is the project/library dependent solution that I promised yesterday:
I hope it helps somebody.
Br, Miha
post-17162-026996900 1281681535_thumb.pn
  • 2 years later...
I am pretty new to LVOOP as well but I found one way to do something similar. I added a dynamically dispatched VI to all levels, but the top level, that looks like this:
The top level passes an empty string out in my case. Each child calls the parent method and the concatenates the strings given in the constant of each. I was trying to mimic the path given in a shortcut menu selection event. Through this means you could construct an array instead of concatenate.
  • 5 years later...
I was looking for getting ancestry list at RT solution for a while. Found few posts, did some coding - no success. I just reply to this old post as @Aristos Queue asks why would someone need that information. I wish to flatten/unflatten object to other format than xml. Surely this post is a grate start, but still unable to get TD even whole data is there. If flatten/unflatten to xml function can do the job, there must be solution hidden under the hood.
@Zyga
Here: https://forums.ni.com/t5/Actor-Framework-Documents/AQ-Character-Lineator-working-draft-version-of-serialization/ta-p/3512840
It's my complete, working flatten-to-anything-unflatten-from-anything serialization library for classes [and any other lv data type]. I forget exactly how the names are extracted, but the functions are in there if you want to use them for your own serialization project. Also, feel free to use the library as it stands.
Expand
From what I see they are not. Correct me if I am wrong, but this lib enforce "serialize" method to be overwritten and then calls it through whole hierarchy.
Disadvantage of that solution is a need to change inheritance. Ok, but enough of moaning. We will use one of existing solution. Just wanted to point out where retrieving ancestry list would be useful (wonder why this information is not in the class flattened string?).
Expand
Oh, yeah. I forgot about that. There's a whole writeup somewhere discussing why I did things the way I did for that library. It's been a while since I worked on it. Sorry for the wild goose chase.
Expand
Flattening the names of the complete ancestry into every flattened string would be an incredible bloat of the flattened size of data.
Expand
I do not believe this is a disadvantage. Serialization is special... if the parent is not serializable then the child is not serializable. Requiring inheritance from a base Serializable does not seem to me to be a bad requirement. Even in other languages where serialization is an interface, mostly they have to add special syntax checking to make sure that the interface is implemented by the eldest class or else it doesn't work. Serialization isn't functionality that can be injected on a descendant level. It's all or nothing to be meaningful because failure to preserve parent state means you aren't actually saving the state of the object. Thus the requirement to inherit from specific base seems absolutely reasonable to me... indeed, it is an advantage because it syntactically assures that the ancestors are included.
  On 9/10/2018 at 3:50 PM, Aristos Queue said:
Expand
Expand
Now when I am thinking of it, it sounds obvious. I am possessed by flatten to/unflatten from xml ease of use..
Expand
Expand
Once again, now mentioned it is perfectly plain. For me it is hard to imagine using more than 3-4 inheritance levels, but looking on e.g. VI Server I see it is reasonable to have more than that.
Edited by Zyga
Expand
The attached file extracts the relevant slides from a presentation I made at NI Week presentation 2012 that presents just such a case. (I left the slide on Transition Execution Sequence at the beginning of this selection because of the reference.)
The hierarchy can be determined at compile time and stored (not so robust), or at run-time using a couple somewhat complex approaches (adding code to the classes to derive the hierarchy, or attempting casting and see if it fails). Reflection would provide a solution, I think. (The hierarchy could still be determined once at the beginning of program execution.)
TS8237_Lotz_ReflectionExtraction.pptx
