Protected Folders In LabVIEW Project Library
  On 8/26/2010 at 7:36 PM, Aristos Queue said:
Really? Even though I likely buddied the code that introduced this bug?
Most definitely. It took 2hrs 14 minutes to lodge a CAR.
(Plus it hasn't been responsible for killing a customer's app - its scripting stuff, which in LV2009 is NI Labs and not supported - so you are off the hook).
Compared to this which took 720+ hrs to start lodging CARs (and a lot more effort).
Anyways - you will notice that I am pretty liberal with my Kudos - just a small way to say thanks to those for helping me, no matter how big or small the issue is
As it always big to the person trying to solve it! :)
  On 8/26/2010 at 10:06 PM, Black Pearl said:
difference between engineers and journalists:
journalist: who can I blame
engineers: who can I get to fix it (otherwise I need to fix it)
I was working on a dual degree in both Journalism and Comp Sci. I didn't finish the Journalism degree -- had one year left to go and decided to focus on CS -- but I did work on the university newspaper for years. I don't think that is a fair evaluation of the journalist. Indeed, I found the two degrees most compatible.
  On 8/26/2010 at 11:15 AM, jgcode said:
I can script Protected folders into a Library.
Bug?
Does a protection library function behave just like a private function?
