use XML with XML Response of a web service
Hi, Im new with LabVIEW, and i have a problem using the web services. I want to have more information with the response of the web service, so I use XML to format the output (with "flatten to XML").
The problem is that i want to recieve the response in XML, and when i recieve the response, the symbols < and > of my XML tags had been modified.
For example, i want to recieve some code like this:
<Response>
<Terminal>
<Name>
example
</Name>
<Value>
<String>
<Val>
Example text
</Val>
</String>
</Value>
</Terminal>
</Response>
but i receive this:
<Response>
<Terminal>
<Name>
example
</Name>
<Value>
<String>
<Val>
Example text
</Val>
</String>
</Value>
</Terminal>
</Response>
PS: Sorry for my english it is very poor.
The idea is to use the web service with ajax, so i can parse the xml to load the result of the operation, so i can't use this solution. Can I configure the LabVIEW's response not to change that escapes characteres? or any similar solution?
thanks for all responses.
You should not be seeing the & replacements when calling the web service. Try calling it from IE or Firefox and see if you still get them. I don't with any of my web services. This could be a problem with the tool you are using to call the web service and not LabVIEW.
Any decent XML parser should know to convert < to a < character.
I'm using Firefox. I configure the output of the web service like a XML file, and I receive it well in my browser, but when I add some XML additional tags, the special characters of those tags were changed, so when i try to parse the XML response with javascript, it didn't recognize the < character like the < character.
Use the javascript "html_entity_decode" function.
html_entity_decode(string)
Normal chars will remain unaffected but   &alt etc will be converted.
