kitekrazy Posted October 15, 2010 Report Posted October 15, 2010 (edited) Hello folks, sorry if I'm a hassle, I'm a newbie here! Trying to control a Tek TDS3054B thats networked to the computer, running LV2009. I would like to control the time base and the input voltage of the scope for measurements, the usual signal is a 10us pulse on a 50hz frequency, 5v logic. MAX is all set up (I think!) and I've the drivers in the Instrument I/O OK. looking for best way to read data for test and measurement purposes, any hints would be much appreciated. Peter. Edited October 15, 2010 by kitekrazy Quote
ShaunR Posted October 15, 2010 Report Posted October 15, 2010 Hello folks, sorry if I'm a hassle, I'm a newbie here! Trying to control a Tek TDS3054B thats networked to the computer, running LV2009. I would like to control the time base and the input voltage of the scope for measurements, the usual signal is a 10us pulse on a 50hz frequency, 5v logic. MAX is all set up (I think!) and I've the drivers in the Instrument I/O OK. looking for best way to read data for test and measurement purposes, any hints would be much appreciated. Peter. TDS3054B Quote
Clio75 Posted October 15, 2010 Report Posted October 15, 2010 I communicate with some scoop, and on all of this I have made my own sett of driver. The reaon is that i didn't find the function in the driver from manufacture or at NI.com. But of course you need to find the cmd to the tex scoop. good lock Quote
alesei Posted October 16, 2010 Report Posted October 16, 2010 Hi maybe this help, work with a similar scope cheersTektronix_TDS3014B_getData.vi Quote
kitekrazy Posted October 22, 2010 Author Report Posted October 22, 2010 Many thanks to you all for your replies, all were useful, and I'm getting there. looks like I will require to make my own commend line to get some of the results I require as they are not directly available. Regards, Peter Quote
Clio75 Posted October 22, 2010 Report Posted October 22, 2010 Many thanks to you all for your replies, all were useful, and I'm getting there. looks like I will require to make my own commend line to get some of the results I require as they are not directly available. Regards, Peter Good lock Quote
