I use several conditional disable symbols in my project. I'd like to create a build script for each spec that sets the symbols to a value appropriate for that build. Is there a way to retrieve the symbol names and values using scripting or vi server? This is as far as I got when I realized I have no idea how to proceed...
I've been meaning to post this:
I've been working on "LabVIEW Project.lvlib" but it's not really ready for prime time. Would be good to have some collaboration.
Modify Conditional Symbol.vi
  • 2 years later...
This post is kind of old, I don't know if JGCode released his project API, so my apologies if this is already somewhere else.
I just wanted to add a note here in case someone else tried to use the project API.
The tags used in the build specification for the version have changed. JGCode uses inside "Executable Get Version_jgcode_lib_labview_project_api.vi" :
App_fileVersion.major
App_fileVersion.minor
App_fileVersion.patch
App_fileVersion.build
at least on the version I am working on now (LabVIEW 2012) the tags are:
TgtF_fileVersion.major
TgtF_fileVersion.minor
TgtF_fileVersion.patch
TgtF_fileVersion.build
Also, this is only useful in development mode, because as MJE showed in this post: http://lavag.org/topic/15473-getting-the-version-of-a-build-from-the-project/?p=93474
you can use that vi to extract the actual exe version at run time.
  • Like 2
  • 1 month later...
  • 1 year later...
