dblk22vball Posted November 11, 2010 Report Share Posted November 11, 2010 I am having an issue where a dat file seems to have been corrupted and so I cannot read all of the data. If you look at the dat file, you can see that all of the data is in there, it just seems that somewhere along the way, something happened and the native LabVIEW dat reader errors out on me. I can use the Read Spreadsheet file to get all of the lines, but they are not in a format that is usable for me, and there is a square character between each entry (my data is a cluster of 10 elements for each entry). If I change the indicator on the output of the Read Spreadsheet.vi, I can see that the "data" that is in between my data is \s\s\s\##, where the ## is the number of characters that will be following it, aka 2.423 is 05. Here is a sample line from the file: Fixture\s1\s\s\s\12\s12:10:50\s10/29/10\s\s\s\041437\s\s\s\07S90-284\s\s\s\052.863\s\s\s\s\s\s\s\04Fail\s\s\s)Flow\sRate\sout\sof\sRange\s\sPressure\sin\sRange\s\s\s\s\s\s\s\s\14Retest\sNot\sRequested\s\s\s\0428.6\s\s\s\0460.8\s\s\s I can use the Search and replace vi to get rid of the spaces (\s) with what ever I want, but the \## I cannot get rid of it for the life of me. I dont care how long each field is, I just want the text. Please help with my mental block, thanks. Quote Link to comment
PaulG. Posted November 11, 2010 Report Share Posted November 11, 2010 This sounds like a binary file that cannot be read back properly because you are not using the cluster that was used to save the data. Quote Link to comment
dblk22vball Posted November 11, 2010 Author Report Share Posted November 11, 2010 (edited) When I try to read back the dat file, I can read the first 133 lines with no problems, and then it errors out saying: Error 116: Possible reason(s): LabVIEW: Unflatten or byte stream read operation failed due to corrupt, unexpected, or truncated data. If I was not using the correct control, it would give me a class conflict error Edited November 11, 2010 by dblk22vball Quote Link to comment
ShaunR Posted November 11, 2010 Report Share Posted November 11, 2010 I agree with Paul G. Sounds like it isn't really a text file (which is what the read spreadsheet is for). Although.To answer your other question about getting rid if \## values..... These are non-printable ascii values. Use the "search and replace string" primitive and right-click on it to select "regular expression". Then create a "search" string. Right click on it to select "\" codes display. Then you can use a string like [\04\12\14]+ to scan and remove the non-printable characters. Quote Link to comment
crelf Posted November 11, 2010 Report Share Posted November 11, 2010 Can you upload the file and the code that you used to write and read the file? Quote Link to comment
MartinPeeker Posted November 12, 2010 Report Share Posted November 12, 2010 I agree with Paul G. Sounds like it isn't really a text file (which is what the read spreadsheet is for). Although.To answer your other question about getting rid if \## values..... These are non-printable ascii values. Use the "search and replace string" primitive and right-click on it to select "regular expression". Then create a "search" string. Right click on it to select "\" codes display. Then you can use a string like [\04\12\14]+ to scan and remove the non-printable characters. Or you can use "vi.lib\Utility\config.llb\Escape String.vi" and "vi.lib\Utility\config.llb\Unescape String.vi" which are pretty good for dealing with these things (Although I believe I had to add something to deal with spave character '/20') //Martin Quote Link to comment
ShaunR Posted November 12, 2010 Report Share Posted November 12, 2010 Or you can use "vi.lib\Utility\config.llb\Escape String.vi" and "vi.lib\Utility\config.llb\Unescape String.vi" which are pretty good for dealing with these things (Although I believe I had to add something to deal with spave character '/20') //Martin Indeed. But if you know there are only a couple of escaped chars; then the above example is much faster. Quote Link to comment
dblk22vball Posted November 12, 2010 Author Report Share Posted November 12, 2010 Shaun, thank you for the info. I had tried using the same search you had listed, but I did not switch it to \ display, I had it on normal display. When I added your search string to my vi, the file was converted properly. Thank you for the help all. Quote Link to comment
