Friends and their Communities
No, not a touchy-feely post about love amongst mankind, but a philisopical question about access scope. I have two classes: Class1 (contains MethodA) and Class2 (contains MethodB). When I set MethodA's scope to community, and I want to put it on the block diagram of MethodB, I need to make MethodB friends with Class1. Why can't I just make MethodB friends with MethodA?
I would imagine it's because a class is an entity and you access that entities data through methods and properties by exposing them to a greater or lesser extent (I think of it like a box with buttons and indicators on it). As such your interface boundary is the "class" so you are in fact saying that the Method B should be able to poke a couple of wires behind the buttons and indicators when all Method B can do is press the buttons and read the indicators.
But then again. I usually over-simplify thingslaugh.gif there's probably a more technical explanation.
Edited by ShaunR
No. It's VIs that don't have friends.
The library (this is not specific to classes) is the thing that defines the access scope of its contained items. The library has to know that an item is a friend to grant it access to the community scope. Granting a particular other VI access to a particular VI within the library is something we could have implemented, but fiddling around with that level of declaration is usually noise -- if a VI not in the library is closely bound enough to the library to need a friend relationship, then it frequently wants access to multiple community scoped VIs, and you've already said that you know this other VI well enough to trust it with general access.
...you know this other VI well enough to trust it with...
So it was all touchy-feely then and about trust wub.gif awhh.....
That's fair.
Sounds like the progression of most relationships. Or is it the opposite?
