Array size from reference
Mellberg
Hello!
Is there any possibility to get the size of an array from a reference to the array?
Since the data type within the array is unknown, I can't convert it to the actual data type and then use the built in 'array size'.
Thanks in advance!
//Lars Mellberg
  On 1/16/2011 at 4:57 PM, Mellberg said:
Hello!
Thanks in advance!
//Lars Mellberg
Hello!
What is an Array? (see next)
  On 1/16/2011 at 6:36 PM, ShaunR said:
Shaun's answer provides the number of visible elements for an Array control.
However you could get the 'Value' of the array control, that would return a Variant with the OpenG function Array Size(s) the actual size of the data stored in the control:
Thanks Ton, looks like what I was looking for!
  • 1 month later...
Please not that this is not exactly a cheap way of determining an array size. The value extraction will create a copy of the array, potentially using quite some memory and also costing performance to do the copy. No problem if your array contains only a few 100 elements but definitely something to think of with an array that could contain 1 million values.
