Farid2010 Posted February 10, 2011 Report Share Posted February 10, 2011 Hi I want to open a video and after finishing that video which is 10 second, a dialog box (another sub vi) comes up and asks for other steps.I used sequence frame (both timed and flat) but the two events still execute simultaneously. I don't know how to use sequence frames in a way that the subvi runs just after the video playing time is done. Can anybody help? Here is my video opening codes Thanks Quote Link to comment
Grampa_of_Oliva_n_Eden Posted February 10, 2011 Report Share Posted February 10, 2011 Hi I want to open a video and after finishing that video which is 10 second, a dialog box (another sub vi) comes up and asks for other steps.I used sequence frame (both timed and flat) but the two events still execute simultaneously. I don't know how to use sequence frames in a way that the subvi runs just after the video playing time is done. Can anybody help? Here is my video opening codes Thanks ActiveX stuff runs in its own world so you will have to poll to see if it still running of generate an event when the vieo comletes. Ben Quote Link to comment
Farid2010 Posted February 10, 2011 Author Report Share Posted February 10, 2011 Thanks Ben I am not that expert. Could you give me more explanation or an exapmle file? Thanks ActiveX stuff runs in its own world so you will have to poll to see if it still running of generate an event when the vieo comletes. Ben Quote Link to comment
Grampa_of_Oliva_n_Eden Posted February 10, 2011 Report Share Posted February 10, 2011 Thanks Ben I am not that expert. Could you give me more explanation or an exapmle file? Thanks Same here when it comes to ActiveX. I would start dropping and wiring invoke nodes and property nodes and wiring them to the ActiveX wire and look for something that looks good or you could try the help for those properties to get a clue. A very long time ago it was possible to get the VBA version of the help for MS stuff by doing an advanced install of the MS stuff and make sure that "Help for VBA" is checked. It will not give you LV code but it will give you VBA examples that can be used as inspiration in LV. Ben Quote Link to comment
Farid2010 Posted February 10, 2011 Author Report Share Posted February 10, 2011 OK Thanks Ben Same here when it comes to ActiveX. I would start dropping and wiring invoke nodes and property nodes and wiring them to the ActiveX wire and look for something that looks good or you could try the help for those properties to get a clue. A very long time ago it was possible to get the VBA version of the help for MS stuff by doing an advanced install of the MS stuff and make sure that "Help for VBA" is checked. It will not give you LV code but it will give you VBA examples that can be used as inspiration in LV. Ben Quote Link to comment
ShaunR Posted February 11, 2011 Report Share Posted February 11, 2011 You could attach a callback to the status event and invoke your dialogue with the one of the status changes. Here's an example of hooking the status event. You might have to browse for the WMM activeX control again if you are using LV32 (I'm using x64) Quote Link to comment
Farid2010 Posted March 7, 2011 Author Report Share Posted March 7, 2011 Thank you ShaunR Quote Link to comment
