p27182 Posted September 19, 2011 Report Posted September 19, 2011 I certainly consider myself a noobie here and with LV, my coworker just showed me how he uses the disable structure- I think it will prove to be useful for me in the future. I wanted to ask a question though- if you tell LV to build an EXE from VI, and the disable structure has some code disabled, is any of that disabled code compiled into the exe? or just left out? thx for any info -pat Quote
Phillip Brooks Posted September 19, 2011 Report Posted September 19, 2011 If I recall correctly, the code in the disabled structures is treated the same as a comment in text based langauges. It does not get included in the built executable. LabVIEW does allow you to build a 'debug' exe. I don't know if the disabled code would be included or not... Quote
asbo Posted September 19, 2011 Report Posted September 19, 2011 LabVIEW does allow you to build a 'debug' exe. I don't know if the disabled code would be included or not... My impression is that this feature allows you to debug a built executable the way you would VIs, to some extent (see block diagrams, and the like). Since the disable structures are on the block diagram, I would think would have to be included? This may not force subVIs in disabled cases to be built and linked, however. Quote
jgcode Posted September 19, 2011 Report Posted September 19, 2011 If I recall correctly, the code in the disabled structures is treated the same as a comment in text based langauges. It does not get included in the built executable. Yes, this is what the help says: Diagram Disable Structure In the Diagram Disable structure, shown as follows, LabVIEW does not include any code in the Disabled subdiagrams when compiling. LabVIEW does allow you to build a 'debug' exe. I don't know if the disabled code would be included or not... I would have assumed debug mode to be similar to edit mode - but it probably doesn't matter what it does because you can't edit the code (obviously). Quote
Aristos Queue Posted September 20, 2011 Report Posted September 20, 2011 Debug mode doesn't change what code is compiled, only how it is compiled. Disabled code is left out either way. 2 Quote
p27182 Posted September 20, 2011 Author Report Posted September 20, 2011 Thanks a lot for the info! I'll take a good read of the help pages next time -pat Quote
Aristos Queue Posted September 21, 2011 Report Posted September 21, 2011 I'll take a good read of the help pages next time You made a tech writer's day. :-) Quote
