mariuszl2 Posted January 31, 2012 Report Share Posted January 31, 2012 Hi, recently I`ve been thinking about buying a FPGA starter kit to use with LV, but I cant find the list of FPGA boards that LV supports. I`ve been thinking about Spartan 3 200K, because it`s fairly cheap and easy to get in Poland. Can you recommend any other FPGA boards that LV FPGA driver supports? The price that I`m willing to pay is ~200 $. Quote Link to comment
hooovahh Posted January 31, 2012 Report Share Posted January 31, 2012 I have never heard of being able to use a FPGA board with LabVIEW, that wasn't a NI FPGA hardware solution. I'm not saying you can't use a different board I've just never heard of anyone doing that. If you must use NI hardware (which I suspect is the case) the cheapest PCI model is going to run you $1500 just for the card, which is a DIO only card at 40MHz and 1M gates. http://sine.ni.com/nips/cds/view/p/lang/en/nid/202011 That's not including the cables or terminal blocks. One other possible option is develop in LabVIEW, then compile to VHDL, then burning that to your generic FPGA card. I've never done this and am unsure if it can be done. I assume at some point the compiled VHDL code is available but you will probably have a difficult time properly addressing hardware IO on a different FPGA. Quote Link to comment
mariuszl2 Posted January 31, 2012 Author Report Share Posted January 31, 2012 Well, I was inspired by this video: Quote Link to comment
jgcode Posted January 31, 2012 Report Share Posted January 31, 2012 I have a Spartan 3E - but obviously NI supply drivers for it which enables it to work with LabVIEW. Quote Link to comment
JamesMc86 Posted February 1, 2012 Report Share Posted February 1, 2012 I think in the video he is probably referring to the academic top board at http://sine.ni.com/nips/cds/view/p/lang/en/nid/207010. The is no way to generate the VHDL for non NI targets from LabVIEW FPGA. Tge top board may work for you. Have a look through the manual but I believe you could power and use it without the ELVIS. You can also target this using Xilinx ISE and by drawing digital schematics in Multisim (requires particular versions of ISE to script but it's pretty cool! The next cheapest way onto the platform would be the single board RIO eval kit. It has recently dropped in price and included 180 days of FPGA and RT. Hope this helps! Quote Link to comment
JamesMc86 Posted February 1, 2012 Report Share Posted February 1, 2012 Now I have managed to look at the video properly on my laptop it appears he is not referring to that board but a Xilinx board called the Spartan 3E XUP (Xilinx University Program). There is an old thread discussing this at http://lavag.org/topic/10838-spartan-3e-fpga-board/ but the long and short is that it is a board from Xilinx for academics and we have written a driver for it, but you have to agree to be using it for academic purposes. The page describing this is at http://digital.ni.com/express.nsf/bycode/spartan3e and there is some training material for it available at http://zone.ni.com/devzone/cda/tut/p/id/6848 if you take the plunge! Cheers, James Quote Link to comment
bmouring Posted May 11, 2012 Report Share Posted May 11, 2012 I should really check these boards more often: yes, NI releases support for our internal Digital Electronics FPGA board (which can dock to an ELVIS II or be used separately) as well as the Spartan 3E XUP (500K version) board, however support for that board, as James noted, is limited to academic use only. Quote Link to comment
eddy70 Posted October 25, 2012 Report Share Posted October 25, 2012 Check this site http://sine.ni.com/nips/cds/view/p/lang/en/nid/11834 This contains all the FPGA that is compatible with LV Quote Link to comment
asbo Posted October 25, 2012 Report Share Posted October 25, 2012 Check this site http://sine.ni.com/n...ng/en/nid/11834 This contains all the FPGA that is compatible with LV Where? Product pages load with a default tab selected. Quote Link to comment
