Multicolumn Listbox - Edit cell
I've been asked to allow editing of a database table in a multicolumn listbox. I used to use a dialog to edit the record's contents, but now it would be nice to edit 'in place'.
If you select a row and then select a cell, the cell changes into edit mode.
I've tried various combinations of properties and looked through the methods to try and find how to set a cell to 'edit mode' programatically, but just can't find the right combination.
The fields marked <REQUIRED> would be set to edit mode in succession until all <REQUIRED> fields are filled in or until the user selects a different control on the FP.
Anyone know how to coax the cell into 'edit mode' programatically?
  • 1 month later...
