george seifert Posted April 11, 2012 Report Share Posted April 11, 2012 I have a subVI that calls subVIs that in turn call other subVIs. I need to be able to run the top level subVI in parallel with itself. At what level do I need to use reentrancy - just at the top level or do all the subVIs down to the lowest level all need to be reentrant? George 1 Quote Link to comment
crossrulz Posted April 11, 2012 Report Share Posted April 11, 2012 My understanding is that for true parallelism all of the subVIs should be reentrant. If you have VIs that are really short/fast, you could possibly get away with not making them reentrant to save a little memory. I will throw out the warning to be careful about VIs that need to maintain state (FGVs, Action Engines, whatever you want to call them) and reentrancy. 2 Quote Link to comment
GregR Posted April 11, 2012 Report Share Posted April 11, 2012 There are a lot of considerations when deciding which VIs to make reentrant. Its about finding a balance between maximum performance and minimum memory usage. Any VI that maintains state needs to be either non-reentrant or fully reentrant depending on its requirements for that state. If there are any VIs that truly can't be called at the same time, those should stay non-reentrant. This could be things like configuration dialogs or file modification. Non-reentrant VIs are one of the easiest ways to serialize access to single instance resources. Any VI that is part of a performance critical code path probably should be made fully reentrant. This avoids synchronization points between multiple parallel instances of performance critical code or non-performance critical code getting in the way of performance critical code. Beyond that you can start to favor non-reentrant or shared reentrant to reduce memory usage. As crossrulz said, VIs that always execute quickly can be considered for leaving as non-reentrant. Keep in mind that there is a difference between a VI that always executes quickly and one that typically executes quickly. Anything that does asynchronous communication (networking, queues, ...) should be considered slow, because it could take longer than expected. Making VIs that are called from a lot of places shared reentrant instead of fully reentrant will slightly increase execution time but can greatly reduce the number of instances required and thus memory usage. 2 Quote Link to comment
