Pollux Posted April 25, 2012 Report Posted April 25, 2012 Hello, Background: I am trying to build an application to monitor the power line of a factory because it is very noisy and we get quite often line stops that affect production. I designed a data acquisition program in Labview using a NI-USB DAQ 6008. It works but the results are not satisfactory since I only have 3kHz per channel (I use 3 channels) so I don't get to see higher frquencies that probably are the reason of our problems. So I switched to NI-USB DAQ 6210. This way I have a 13kHz acquisition rate so I get acces to the 13th harmonic (b.f. 50Hz) and do some oversampling to avoid aliasing. To acquire the signals I use a separation transformer 400V/4V. Problem: I have tested my application in lab, trying to measure a DC voltage of 5.5 Volts and this is what I get: I would have expected to have a continous line since it is a DC voltage that I put on the channels. Repeating the test for other voltages gave similar results. It's like loosing the signal for some fractions of a second. You can see here the configuration of the acquisition task in MAX: I have done the physical connections on the board acording to the indications that MAX gives for Differential measurement. I have also tried to do a calibration. It seems to saturate above 4V as you can see below: It is true that this calibration is done with a standard DC power source that probably has a deviation of tenths of milivolts. I have also tryed with a precision source from Fluke that the Metrology department has but I don't get better results. You can also find a calibration report attached. Supposing that the board is deffective I exchanged it for another of the same type (6210) but I have the same problem. It is also possible that both boards are deffective since I don't know their history before my arrival in the company. What do you think is the problem? Thank you. calib.htmlFetching info... Quote
Tim_S Posted April 26, 2012 Report Posted April 26, 2012 (edited) Just as a note, if you're out of range with a power supply is 5.5 V and DAQ channel setup of +/- 5 V. I would expect the value to be at the rail rather than the plot you have. Edit: The use of the transformer may very well remove the transient you're looking for. Edited April 26, 2012 by Tim_S Quote
Pollux Posted April 27, 2012 Author Report Posted April 27, 2012 (edited) Could it be that the information quantity is more than the USB can acquire? I'm not sure if on that computer I have USB 2.0. It's an old laptop from 2004 so it could be that it has only USB 1.1. edit: on second thought it can't be. I also tried a 3 kHz acquisition and it didn't work... I suppose the boards are broken. Edited April 27, 2012 by Pollux Quote
JamesMc86 Posted April 28, 2012 Report Posted April 28, 2012 Simplest thing is to try it on another PC to rule this out (tech support will probably ask this anyway if you get it fixed). I would confirm it with another source. Also what if you jut ddo one channel? But sounds like it could be a fault. Especially if you've had to recalibrate the volts (null) Quote
ShaunR Posted April 28, 2012 Report Posted April 28, 2012 Your signal is 20ms (50Hz). That's mains leakage (either in your source or in the USB supply). Change the source to a battery and see if it goes away. If it doesn't, send back the unit and get a replacement. Quote
