[CR] Create_UDL_File_LV2010
index.php?app=downloads&module=display&section=screenshot&id=210
Submitter: Prabhakant Patil
Submitted: 17 May 2012
File Updated: 12 Jul 2012
Category:Database and File IO
LabVIEW Version: 2010
License Type: BSD (Most common)
Create_UDL_File_LV2010 v1.0.0
Copyright © 2009, Prabhakant Patil
All rights reserved.
Author: Prabhakant Patil
LAVA Name: Prabhakant Patil
Contact Info: Contact via PM on lavag.org
LabVIEW Versions: 2010
Dependencies:
1. NI Database connectivity Toolkit
2. OpenG Application Control
Description:
The Microsoft Data Access Components (MDAC) provide the Data Link Properties dialog box as the common user interface for specifying connection information to a data provider on Windows 2000 and later operating systems.
You can use the Data Link Properties dialog box to save connection information in a universal data link (.udl) file.
Universal data link files (or '.udl files') provide a common user interface for specifying connection attributes.
A user can use a Data Link Properties dialog box to save connection information in a .udl file as an alternative to directly specifying them by hand in a connection string.
Consequently, these files provide a convenient level of indirection.
Additionally, the dialog box specifies a number of alternate OLE DB data providers for a variety of target applications
This example is used to generate UDL File. This file is used to connect SQL database.
Installation and instructions:
1. Run Create UDl_SQL. VI
2. Enter Database server name and password
3. Enter Database name and click OK button.
Then it will try to connect database using entered information
Version History: v1.0.0: Initial release of the code.
License:BSD
Distributed under the Creative Commons Attribution 3.0 (http://creativecommo.../about/licenses)
See link for a full description of the license.
Support: If you have any problems with this code or want to suggest features:
please go to lavag.org and Navigate to LAVA > Resources > Code Repository (Certified) and
search for the "Create_UDL_File_LV2010" support page.
Distribution: This code was downloaded from the LAVA Code Repository found at lavag.org
  • 5 weeks later...
  • 3 weeks later...
Please sign in to comment
Sign In Now
