KWaris Posted June 30, 2012 Report Posted June 30, 2012 Hello there, I found out that I need to first save the Labview 5.0 vis into any of the versions from 6 to 8.2. Then these could be directly opened and used using Labview 2011. I dont have Labview of these versions. Please advise the method to upconvert these libraries. Kind Regards Austin Quote
jcarmody Posted July 1, 2012 Report Posted July 1, 2012 There's a board on the NI forums dedicated to that kind of thing - http://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion 1 Quote
Prabhakant Patil Posted July 6, 2012 Report Posted July 6, 2012 Also you just download evaluation version 8, or request NI for the same. I also faced this problem earlier. I resoved this using Labview 8. Quote
LogMAN Posted July 6, 2012 Report Posted July 6, 2012 Hi AustinCann, You should ask the NI support if they would update the code for you (they will do for shure, if you have a support contract). It is of couse necessary to send your code to them and you obviously need a support contract. I don't think it is that easy to receive evaluation versions of 6.x, 7.x and 8.x, unless NI has some platform for that (which I've never seen). Greetings, LogMAN Quote
